Stroker396's Avatar
Stroker396 Stroker396 is offline
Car: 535i
Default SMFW and clutch - 06-21-2020, 04:54 PM
$520 Shipped
This is a Turner Motorsports single mass flywheel and a stock F10 550i Clutch rated for 440ft lbs. It has about 2000 miles (1000 highway) It has 8 bolts for the crankshaft.
I had to upgrade to a twin disk as this setup could not hold the power and would rip the clutch loose if the engine made any kind of boost. I drove it like a granny shifting under 4k rpm and light throttle once I realized it was an issue but as you can see it got a little burnt the few times it couldn't hold. This was installed a few months ago. I paid over 800 for it.
08 535i MT Blk. CP w/BOV, JB4, BEF, DCI, edited things delete, Inlets, 7" FMIC, SP exhaust, X Clutch, poly/delrin shifter bushings, Walbro 525, RB PCV, catch can, VRSF oulets, MMP Gen 1 Stg3, 3.5Tbar, 2 step, FSB WMI
Anti Lag up next.
On Hand: JB4 PI Controller
clanmember32 clanmember32 is offline
Car: e36 and e90
Default 10-03-2020, 07:04 AM
Im interested in this setup, how was the engagement compared to stock? Did it create transmission noise at idle? Did you notice any difference in engagement after slipping the clutch? Thanks, -Seth
Stroker396's Avatar
Car: 535i
Default 10-03-2020, 01:53 PM
I did not see a big difference from stock It was a nice setup, smooth engagement. It continued to drive like normal I just had to keep the car out of building high boost so I would shift by 4k rpm.
As for sound I only noticed a slight rattle when in neural with the clutch pedal out. I also added a steel pivot pin for the fork I don't think that helped.
I would have kept it had I not over modded the engine (I was also having an overboosting issue at that time)
Anti Lag up next.
B_MC_83 B_MC_83 is offline
Car: 10' e90 335i
Default 10-19-2020, 10:56 AM
Has the flywheel ever been resurfaced? Would you sell it separately?
Stroker396's Avatar
Car: 535i
Default 10-19-2020, 11:13 AM
No it has never been resurfaced. I bought it new, installed it, realized it was not sufficient to hold all the power i added and replaced it.
Yes I would sell it seprately. 350 shipped
I wont be able to ship til next wed i am out of town.
Anti Lag up next.
Car: 10' e90 335i
Default 10-19-2020, 03:57 PM
Appreciate the offer but I will pass. Looks like alot of heat was thrown at it so it should be resurfaced prior to using again.
