(#3101)
Car: 2019 STINGER GT2
Default 04-17-2020, 06:37 PM
Awesome! But what if you have AUTO wipers?
ghodge ghodge is offline
Car: 2019 Kia Stinger GTS
Default 04-17-2020, 07:38 PM
Wow! I'm glad you are working on this. I like how the Accessport V3 for my Fiesta ST integrates with the cruise control buttons to change maps.
George
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 04-17-2020, 07:42 PM
New feature in the works for the Kia JB4.
I'm up for testing! LOL
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
Default 04-18-2020, 11:01 AM
We're looking in to how those work now to figure out the best settings for them. Probably what we'll end up doing is just not disabling the JB4 when wipers are running. So if you're using this feature just be aware your intermittent setting also determines the JB4 map.
Default 04-18-2020, 11:12 AM
The faster the wipers go, the faster you go... GENIUS!
Default 04-18-2020, 11:13 AM
LOL
Default 04-18-2020, 12:32 PM
GT2Crew GT2Crew is offline
Car: 2019 Kia Stinger GT2 AWD
Default JB4 Log - 04-18-2020, 03:47 PM
Hello Terry,
Can you look over this log real quick and tell me what you think please? I am in Albuquerque, NM at 5300 ft elevation and only have access to 91. I would like to run Map 2, so I would like your opinion. Thank you.
2019 GT2 AWD
- Denso plugs gapped down to 0.022
- Injen CAI
- Ark mids + MBRP catback
- ADD W1 OCC
Default 04-18-2020, 08:07 PM
For those testing the new v15 firmware we are working on getting the app interface updated to make the setting entry a little easier. This is currently how you enter the maps to select on the wiper setting. None of these settings are currently being used on the Stinger platform for anything (all WMI mapping other than min boost is internal to the firmware) so was a good area to reassign to map switching.
Default 04-18-2020, 08:10 PM
Originally Posted by GT2Crew
Hello Terry,
2019 GT2 AWD
- Injen CAI
- ADD W1 OCC
Looks good but v7 firmware only has cyl1 timing.. Update it to the latest v14 and relog so we can check cyl 2-6!
atr1 atr1 is offline
Car: Stinger GT
Default 04-18-2020, 08:26 PM
Min Max RPM setting wasnt used ?
ck awd korea ck awd korea is offline
Car: stinger gt awd
Default 7map log - 04-19-2020, 01:59 AM
This is map number 7. Is there anything I need to supplement? The hardware is stock. awd
Default 04-20-2020, 08:03 AM
Will do thank you.
Tdgkorn Tdgkorn is offline
Car: G80 3.3T Sport
Default 04-20-2020, 12:00 PM
Hey Terry,
I ran a few tests on E30, hoping you could take a look.
G80 AWD
Denso's Gapped
Elev. 6200
First two are map 6 set to 4.7
third is map 3, 3rd gear
fourth is map 5, 3rd gear
Default 04-20-2020, 01:17 PM
It's not, all WMI settings other than min boost are internally mapped.
Default 04-20-2020, 01:19 PM
No changes needed, looks solid to me! Could try raising WMI additive up 5-10 to see if more boost further helps performance.
Default 04-20-2020, 05:05 PM
v15 BETA is up on the firmware server so we can have a few of you test out the in dash map switching. Had a G80 test it and confirmed the signals are different so I'll need to grab one locally for a day to set that up. Could use a G70 test also.
Car: Stinger GT
Default 04-20-2020, 05:29 PM
G70 works.Tested on 1 car.
I had a report of 1 Veloster on which didn't work while it worked on another one.
Tunder Tunder is offline
Car: 2020 Kia Stinger GT Limited AWD (CAN)
Default AFR broken? - 04-20-2020, 05:39 PM
Hi friends, I think my AFR is broken. It worked before, IIRC.
Default 04-20-2020, 05:41 PM
Also, check out this sick mount I made for a Fire HD 8 hehe
Default Map 1 - 04-20-2020, 06:33 PM
Here's a pull from 0 to as fast as I had road for. I don't think it's pinging anymore, at least, I can't hear it with the windows up. If someone could take a look at it I'd be stoked!
Car: Stinger GT
Default 04-20-2020, 10:22 PM
Your timings are not very high. What fuel are you using?
Default 04-20-2020, 10:45 PM
Thanks for the reply... I'm using Chevron 94 octane, no ethanol. It seems to have improved since I installed my JB4. Is it ok otherwise?
MurlinatoR's Avatar
Kia Efficinato
Default 04-21-2020, 12:34 PM
Confirming that it functions perfectly on mine and I LOVE IT! So much easier to change maps on the fly and without needing the app even open... genius! Real game changer! Now I can run around stock or on map 1 and when some turd wants to play I can roll it to map 6 with 20+ pounds of boost to play with!
Thanks Terry!
2018 GT AWD.
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
Default 04-21-2020, 03:00 PM
Thanks. Was model year different between them?
