Zombie1 Zombie1 is offline
Car: 2010 135i
Default Upgrading turbos need advice. - 10-27-2017, 03:55 AM
So Iím looking to order a set of pure stage 2. My only question is should I spend the extra money for the hiflo ones? My cars an auto so I donít want to nuke transmission. Looking to run e40 make 5oowhp thoughts?
Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default 10-27-2017, 09:45 AM
yes do hi flow, u can run them less than full potential for that power goal and be reliable
335- stock
Car: 2008 E93
Default 10-27-2017, 12:35 PM
DD version. Easily hit that goal and spool a lil quicker.
Car: 2010 135i
Default 10-27-2017, 12:43 PM
Welp, two replies two different answers lol. I’m just looking for a reliable set up I’m not looking to replace turbos every 20k.
Pure Turbos's Avatar
Default 10-27-2017, 01:07 PM
Both will make 500whp easily. If you think you may get the itch to crank up the boost in the future, go with the High Flow to leave some headroom for future enjoyment
Car: 2008 E93
Default 10-27-2017, 10:26 PM
Yes, but keep in mind its NOT that simple. Crank up the boost as you say.....supporting mods and fuel is a hurdle that has to be crossed b4 more boost can be achieved.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-31-2017, 09:55 AM
DD version
Alpine1 Alpine1 is offline
Car: 2009 135i alpine white
Default 11-01-2017, 05:17 PM
If you keep your options open you should consider Rob from RB Turbos. Rob will listen to your wants or concerns and will put together an awesome package that will meet your expectations. This is his info if your up for the Pepsi challenge.
RB Turbos for the win!!!
kennejp's Avatar
kennejp kennejp is offline
Default 11-06-2017, 08:09 PM
Hi flow for sure! Honestly not even a question in my opinion. Our shop has installed tons of upgraded turbos from all the vendors and ive never heard any of them say "I wish I had gotten smaller turbos" but have DEFINITELY heard them say "I wish I had gone for the bigger ones" a few months down the road when they want more power. Just my .02c!
07 E92 MT RB Turbos-600whp
08 E82 Built engine/trans Speedtech ST 6466
Riceball777 Riceball777 is offline
Car: 2007 e90 335i
Default 11-07-2017, 02:01 AM
i have had the pure stage 2 DD turbos for the past 6 months and i love them. Great power and great spool.
2007 e90 335i
pure stgae 2 DD turbos, rb inlets, bms 4 bar map sensor
Jb4 with mhd hybrid e85 back end flash, vrsf down pipe vrsf 7" intercooler, vrsf charge pipe with tial bov and afe intake. Fuel it stage 2 pump and fuel line/ethanol content kit.
spec stage 2+ clutch with new oem dmfw
mp335 mp335 is offline
Car: 09 335i
Default 01-28-2018, 07:59 PM
Could you please share your thoughts on these:
a) what are the main differences in DD vs high flow version?
b) if reliability at 500whp is main concern which version you would recommend?
thanks!
Car: 09 335i
Default 01-29-2018, 08:35 PM
thanks!
Pure can you comment? Since there no specs out for these turbo relying on your feedback.
Default 01-30-2018, 12:31 PM
We don't post specs. All custom Pure spec wheels. Both are equally reliable at 500whp. If that's the power level you're shooting for, definitely go with the DD! There are many dyno sheets out there with the DD turbos, making up to 600whp. So 500whp will be easy with those! As for spool, you can see Terry has even the high flow turbos spooling at ~3k rpm at his last dyno, so both spool very well.
Customer running DD:
http://www.n54tech.com/forums/showthread.php?t=45589
Terry BMS dyno:
Car: 09 335i
Default 01-30-2018, 07:36 PM
Terry BMS dyno:
thanks for the update Pure! appreciate it.
BigFaceHuncho BigFaceHuncho is offline
Car: 2009 335i E92
Default 03-05-2018, 04:37 PM
How much rwhp can the Auto transmission handle with out the transmission slipping? I just bout me a 2009 335i E92 with 44,000 miles
Car: 2008 E93
Default 03-05-2018, 05:40 PM
You should do a search. This has been discussed b4. There is no straight answer. People have slipped at 400whp some not until 600whp +. Just as people have blown motors at 400whp +, yet others have done 650 to the wheels on stock internals still.
LessIsMore's Avatar
Inner Circle Member
Default 03-06-2018, 09:39 AM
I think the best plan for an auto is:
a) upgrade the internals with new valve bodies, zip kit, fluid, etc.
b) XHP TCU flash
c) keep whp under 600 most of the time
d) start saving for when, not if, the auto starts slipping - could be 50K mi, could be 500 mi, varies based on a lot of factors, but the above measures will make it as strong as possible without a full rebuild.
