itscuzimmaturk itscuzimmaturk is offline
Car: 08 335i e93
Default 3.5 tmap sensor - 12-28-2016, 11:29 PM
So i was checking it out and my buddy said it boosted up his psi by like 2, do i just plug and play? Or do i have to get something done for it to push up the boost? My mods are just jb4 g5, intakes and intercooler
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 12-28-2016, 11:44 PM
3.5bar tmap sensor is needed if you push your boost beyond capabilities of stock tmap (as i remember 21 psi)
with that mods i doubt you will hit that boost
2007 E92 335
ST - GTW3684
JB4 G5, ST Pump Flash, Fuel-It Stage 1, Meth
MT (after swap),
MFactory LSD
08_335i 08_335i is offline
Car: 2008 335i
Default 12-29-2016, 01:26 PM
The sensor doesn't increase your boost. It allows you to run higher then 21(ish)psi. if you plan to run FBO, upgraded turbos, single turbo, etc, then I would suggest getting it as you'll most likely want to run higher boost levels.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 12-29-2016, 03:54 PM
Make sure you set the JB4 up properly and tell it you have the N20 map
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: 2007 BMW E90 335i
Default 12-29-2016, 06:26 PM
Your buddy is an idiot. It doesn't increase boost PSI, it simply has a wider range than the stock sensor. However, you MUST change the tune (or settings in the JB4) when you install the sensor otherwise it will not run correctly.
2013 135is DCT Carbon Black
Default 01-02-2017, 02:21 PM
It raises the boost range from ~20psi to ~36psi. You'll need the adapter on our site, the sensor from BMW, and then to tell the JB4 you have a 3.5bar TMAP sensor on its settings page.
