(#2526)
djlilmikeny1 djlilmikeny1 is offline
Car: 2011 BMW 335is
Default 05-23-2016, 06:08 PM
Originally Posted by Rsoxs19
How often does the flash fail because I'm really scared it will mess something up. If it does fail why could I do to get it back to normal? Thanks!
Basically the only reason a flash would fail is human error. Make sure your device is near fully charged. Make sure your car's battery voltage stays above 12v by using a battery charger or using jumper cables to another running car. While the flash is occurring, do not open or close doors, Windows, touch switches.. Etc.. And do not touch the INPA cable. When I flash, I open my driver window, plug the INPA cable in to the car and phone, get out of the car, and close the door. And just work the phone thru the window and put the phone on the drivers seat while flashing and don't touch it till it's absolutely complete.
mkster08 mkster08 is offline
Car: 2008 335 AT
Default 05-23-2016, 06:10 PM
Yup this
Rsoxs19's Avatar
Rsoxs19 Rsoxs19 is offline
Car: 2007 335i e92
Default 05-23-2016, 06:14 PM
About how long did it take you for the jb4 backend flash because I'm also worried about my phone dying.
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 05-23-2016, 06:20 PM
If you start with a fully charged phone you have no worries.
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Default 05-23-2016, 06:27 PM
Takes about a half hour. No problem.
N54 | Build Thread
Rsoxs19's Avatar
Car: 2007 335i e92
Talking 05-23-2016, 06:42 PM
Thanks for all of the responses, I feel much more confident now! Just have to wait for cables to come in and should be done on Wednesday. Thank you!
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 05-23-2016, 06:44 PM
Just flashed back to stock yesterday (19 min) and then updated pump flash (38 min)
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default Update - 05-24-2016, 03:24 AM
Hi Terry,
Would Please update the Software Version about MSD type or car models for IKM0S.
Thanks.
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Default 05-24-2016, 08:19 AM
Originally Posted by quattr0
Gents
I still have jb4 mhd 091315 pump (93) installed. Question: Should i get the latest pump or kr map in light of what Terry posted in the JB4 BEF new features and testing post that stage 2 mhd target is high?
Many thanks!
Not sure what you're talking about but run the latest JB4 PUMP BEF if using 93 octane no meth.
N54 N54 is offline
Car: 2008 E92 335i
Default 05-24-2016, 10:01 AM
Will the BT Scan Tool work with the MHD Android Flash?
Car: 2008 335 AT
Default 05-24-2016, 10:09 AM
Nope, but the inpa K+dcan cables for ~$30 on Amazon do
bk335xi's Avatar
bk335xi bk335xi is offline
Car: 335xi 6MT
Default 05-24-2016, 10:12 AM
You know you don't have to flash back to stock to update the map.. right? Just flash the newest map, should take 2 min.
08 335xi 6MT | FBO
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 05-24-2016, 11:04 AM
What map should we be using for Meth? My car doesn't seem to like the MHD e85, pump or race back end flashes.
Best results to date have been the BB e85 flash. Anyone else find this?
Frustrating since i dumped quite a bit of cash into the MHD software.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-24-2016, 12:41 PM
Originally Posted by ryanm8
How does the new shift light feature work along side the JB4 blinker shift light?
MHD shift light is displayed on the Android devices while running the MHD gauges. Which is not compatible with a running JB4. Basically, MHD shift light is flash only.
For meth, race flash. Post log in the support section if you have issues.
quattr0 quattr0 is offline
Default 05-24-2016, 01:08 PM
Thank you, Terry.
Rsoxs19's Avatar
Car: 2007 335i e92
Default 05-25-2016, 07:52 PM
I just installed the jb4 pump backend flash today. Only took 22 minutes. How long should it be before I expect a difference in power from the flash?
Car: 2008 335 AT
Default 05-25-2016, 09:07 PM
Almost right away? It's not gonna be huge massive 50hp gains, but smoother power, you should notice it fairly quick. Also make sure you set your jb4 correctly, menu 4 needs to have option 2 on.
e91 335i e91 335i is offline
Car: BMW e91 335i
Default 05-26-2016, 01:23 AM
Originally Posted by e91 335i
I had similar issues with the lates e85 hybrid flash for I8AOS. When I switched back to E85-flash the car runs perfectly again. Any ideas what is wrong with the hybrid BEF?
The AFR rises, fuel pressure drops and also a sudden overboost. Also the car was a bit jerky with hybrid BEF.
Anyone using hybrid BEF? Is e85 hybrid map working properly?
bk335xi's Avatar
Car: 335xi 6MT
Default 05-26-2016, 11:07 AM
If I'm looking for a base pump map to play with in tuner pro and flash as a standalone, could I use the backend pump? If I'm not mistaken, it can be used as a standalone.
08 335xi 6MT | FBO
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-27-2016, 04:54 AM
Get the ZIP package at https://github.com/dmacpro91/BMW-XDFs
Along the updated xdf, there's the good v8bait Excel file to get you started self tuning flash only.
bk335xi's Avatar
Car: 335xi 6MT
Default 05-27-2016, 05:22 AM
Thanks Martial. I actually already have the xdf. I guess what I meant was I am looking for a .bin file of a pump tune to play with. I tried to find the MHD stage 1 maps that I purchased on my phone but it looks like they can't be accessed. I just want to mess with a few things such as making a ghost cam map for fun, etc.
08 335xi 6MT | FBO
Car: 2008 335 AT
Default 05-27-2016, 08:01 AM
Ghost cam
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 05-27-2016, 08:11 AM
Originally Posted by mkster08
Ghost cam
EW
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
bk335xi's Avatar
Car: 335xi 6MT
Default 05-27-2016, 08:25 AM
Originally Posted by jyamona
EW
Word. Gotta start somewhere when learning tuner pro though.
08 335xi 6MT | FBO
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Default 05-27-2016, 08:44 AM
Originally Posted by ThaCuda
On the desensitized BEF, or even this new KR flash time option.. Is there a percentage that we can relate it to? or is it only an initial timing retard threshold is 0?
Hows about this?
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Conqueryourbimmer
