(#126)
durty sexn55 durty sexn55 is offline
Car: n55
Default 10-16-2015, 05:00 PM
Nice
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 10-16-2015, 05:38 PM
Looks better than this:
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Default 10-16-2015, 05:59 PM
Same functionality though, we just made it a little prettier.
dreyo27 dreyo27 is offline
Car: 2007 335i 6mt
Default 10-16-2015, 07:22 PM
Too sexy, what's going to be the price? I got your es-1 and stage 2 pump, will I be able to run 100% e85 with the TBI kit? Stock turbos FBO JB4 and backend flash with inlets?
Car: 2009 BMW 135i
Default 10-16-2015, 08:09 PM
I have the same mods as you.
I'm running straight E85.
Log before you jump to straight E85, but you should have no problems.
Peter @ Pure's Avatar
Car: F20 M135i
Default 10-17-2015, 01:24 PM
While the prod spacers look nice, the beta ones seem more undercover due to no advertising on it
But they do look good Steve!
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 10-17-2015, 01:54 PM
Not if you rotate it 180 degrees...then it's solid black and you don't see the logo.
Zombie1 Zombie1 is offline
Car: 2010 135i
Question 10-18-2015, 06:09 AM
Steve I'm upgrading to pure stage 2s in the near future. I will be limiting my power to around 550whp, if I keep the power at that or slightly under would this TBI be an option for me?
Default 10-18-2015, 09:26 AM
Yes, you can run throttlebody injection for those power levels, you just won't be able to run 100% E85. On our N55 we make about 540whp on E50 with TBI.
Car: F20 M135i
Default 10-18-2015, 12:26 PM
Oh right Well I am more of a functional guy anyways. I'll stick with mine :P
peter@pureturbos.eu
pureturbos.eu
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 10-20-2015, 10:58 AM
Eagerly awaiting the release. I can't get these RB's to boost lower than 23-24psi and I'm running out of fuel in bank 2.
ksmyth's Avatar
ksmyth ksmyth is offline
Car: 335xi
Default 10-20-2015, 04:15 PM
What conditions can you run 100% E85 on a N54 with this TBI?
09 335xi - 6AT - JB4 - hot side inlets - *** - MHD Flash - 7" IC - Fuel-It TBI
Default 10-20-2015, 04:21 PM
Just got notice more parts are in route.
If you're running stock turbos and FBO, you'll able to run 100% E85 as long as the rest of your fuel system is healthy. If you are running inlets and running aggressive, you may have to reduce your mix a bit, that seems to vary but ultimately it depends on how much power you're making. Up to about 500whp on 100% E85 you should be fine, after that you may have to start reducing your mix depending on how much actual power you're making.
ksmyth's Avatar
Car: 335xi
Default 10-20-2015, 04:54 PM
Thanks Steve. I was thinking of inlets next but frankly at this point I'd prefer to have the ease of use in just adding pure E85 in the tank. I won't have to worry about trying to teach the wife how to mix fuel.
I live up in the great white frozen north. This upcoming winter is my first winter running E85. Oddly we are still at pure E85. At some point I would guess that will really turn into E70. I assume that Class 3 E85 will ensure I can run pure E85 with no issue even with inlets. It will be the summer Class 1 blend that might be an issue with inlets.
Car: 09 E92 335i
Default 10-20-2015, 07:50 PM
Cold start is gonna be annoying with high e85 content under low temp though. But as long as you are ok with some initial rough idle and occasional start up stalls, then it is all good. But I personally just switched back to pump gas for the winter.
That said, I have been running the beta kit for a few months now and probably beat on it more than anyone else at the moment with all the road course events this car have done since then. All I have to say is that it works like a charm.
Car: F20 M135i
Default 10-21-2015, 12:05 AM
Yes I can vote for this kit as well. With just meth and stock HPFP the car just feels less smooth. I ran the last week and a half on 17 psi, 93 fuel and meth (TBI disabled). Then this week I added 35% E and activated TBI again and it just feels so much more smooth. It works really great!
peter@pureturbos.eu
pureturbos.eu
ksmyth's Avatar
Car: 335xi
Default 10-21-2015, 04:20 AM
I installed a garage heater and park under ground at work. The car should be warm enough unless I go somewhere else and park for an extended period.
Default 10-21-2015, 04:38 AM
Our E82 that runs 100% E85 starts up instantly when cold, however it never really gets below about 28 degrees Fahrenheit here.
ksmyth's Avatar
Car: 335xi
Default 10-21-2015, 04:54 AM
-20F here too many days, wind chills in the -50F range occasionally. It's not the desert. ;-)
Default 10-21-2015, 05:33 AM
Ouch...no kidding! I'd definitely reduce the ethanol mixture during those times.
Flash point of:
Ethanol = 63 degrees F
Gasoline = -45 degrees F
Diesel = 100-130 degrees F
http://www.engineeringtoolbox.com/fl...els-d_937.html
ksmyth's Avatar
Car: 335xi
Default 10-21-2015, 07:23 AM
haha! thank you for the engineering reference link. a data geek i am... I've read there are heating elements in the injectors. I wonder what their effective range is.
ksmyth's Avatar
Car: 335xi
Default 10-21-2015, 09:22 AM
Assuming that we do indeed get Class 4 E85 in Minnesota in the very cold months, wouldn't it be safe to say that it will actually work? It should actually only be a much lower ethanol content to allow all the normal vehicles using E85 to start as well.
Default 10-21-2015, 11:38 AM
I'm not sure what the percentage of ethanol is for Class 4 but those can vary from station to station anyways.
I'd experiment with it, work my way up, and see how the car handles it. In addition I'd use the 30 second trick to heat up the injectors on cold starts.
Default 10-21-2015, 11:43 AM
What is the 30 second trick?
Car: F20 M135i
Default 10-21-2015, 11:52 AM
I assume it's just turning the ignition on and wait 30 seconds prior to starting the engine
peter@pureturbos.eu
pureturbos.eu
