(#276)
Sirdaft1's Avatar
Sirdaft1 Sirdaft1 is offline
Default 08-07-2015, 10:40 PM
Sorry for all then crap you're going thru. Wish Level 10 would just step up, make things right with you, and then be transparent with the rest of us if what they have is actually more than snake oil. There would be insane demand for their trans upgrade for us 6AT guys if they weren't so friggin shady.
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 08-07-2015, 10:43 PM
sirdaft1 gimme that trans :D
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 08-08-2015, 10:04 AM
If Level 10 won't work with me Monday on fixing the remaining hardware issues and I have to let the dispute continue, are there any other companies out there willing to tackle my 5th gear problems?
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 08-08-2015, 10:16 AM
Originally Posted by Dmac @ BMS/DMD
Update:
Decided to take a chance and swap the solenoids and guess what...
THE WEIRD SHIFTS ARE GONE!!! The only problem that remains is that the car won't hold 5th gear. 1-2,2-3,3-4 are all fine, but 4-5 slips back into 4th. I'm going to assume this is probably an issue with the clutches as I received a gear ratio monitoring code not too long ago. But this PROVES that the issue was hardware related all along. On Monday I'm going to give Level 10 a call and offer them a chance to make this right. If they want me to drop the dispute/chargeback, I want to be FULLY reimbursed for all of my travel, parts, and labor it took for me to fix something that they should have replaced a long time ago. I'll post video proof that the "weird shift" is currently gone later and will update this thread again on Monday when I speak with them.
Video proof:
awesome!
JB4 G5, ***** flash, 455 LPFP, HFS-4 meth kit, BMS OCC, VM 6466 ST, RB valve, BMS DCI, 3" AR ***, Custom OC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2 exhaust DEFIV kit, KW clubsort, Delrin solid subfrane bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, MORR VS8.2 rims 245/295
enrita's Avatar
enrita enrita is offline
Default 08-08-2015, 11:05 AM
mine doesnt do that at all shifts fine on all gears up to 23 psi (cant boost more on 'E85 till i change lpfp). only issue i have is a weird hooking up when on low rpm, normally between 2200-2600 giving low gas probably when the torque converter is engaging. Mostly on D mode. S mode better because rpm are way higher.
Optigrab Optigrab is offline
Car: 08 135i 6AT
Default 08-10-2015, 08:46 AM
[QUOTE=Dmac @ BMS/DMD;397000]Update:
I don't understand how new solenoids were not included in the super expensive rebuild or the troubleshooting. They must have some quality control issues
wgknestrick wgknestrick is offline
Car: 2011: 335Xi
Default 08-10-2015, 10:07 AM
Just data dumping here what I have found through some heavy Googling:
Exedy offers upgraded clutches for 6R90s (ford variant) and 6HP26
http://www.exedyusa.com/race_clutch/...ssion_kits.php
Exedy claims these clutches have both run sub 10s quarters. We do not know if these are compatible with our transmission. This is hope that some type of solution exists for big HP guys.
Good overview on our transmission and common issues:
https://sayyarti.wordpress.com/2015/...ission-issues/
Link to Sonnax repair kit
http://www.sonnax.com/parts/3052
http://www.sonnax.com/units/415-ZF6HP26
forum experiences from zip kit
http://www.bimmerfest.com/forums/sho...=788295&page=2
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 08-10-2015, 02:36 PM
Have you contacted IPT yet and asked about their rebuilds? I think they do alot more extensive work with the trany AND valvebody than level 10. Its worth a phone call.
livnpaintball2 livnpaintball2 is offline
Car: 135
Default 08-11-2015, 09:44 AM
Level 10 sucks with their over inflated hp ratings, total rip off. I sent my Torque converter to Circle D for rebuild and did my valve body with a Sonnax Zip Kit with new stock clutch packs. Hope to have it running soon.
2016 Mustang GTPP Whipple! 650rwhp, easy..
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Thor 12.9 mega motor installed!
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 08-11-2015, 12:21 PM
Level10=0. They never even returned my e-mails. Over price crap in my opinion.
Car: 2008 135i
Default 08-11-2015, 01:22 PM
Yea, I don't understand either.
Lots of good info!
Depending on how this pans out though, I'll probably just hop on the 4L80E train when it is available.
After thinking about it, if Level 10 won't pull through and correct this situation, I'll probably just wait for the 4L80E build.
Also, I've decided to start recording my phone calls for better record-keeping and complete transparency of my experience with Level 10. According to my research Kentucky and New Jersey are "one party consent" states, meaning as long as 1 person (myself) gives consent, the recording is perfectly legal. I've posted my 3 phone calls with Level 10 since Monday at the bottom of my webpage. If I come across as a jerk in the recordings, sorry. I've been getting the run-around from Level 10 since April.
http://dmacpro91.com/LevelTenSaga/
Edit: I've removed the recordings from my website temporarily. If you're truly interested in hearing how Level 10 handles their phone conversations, pm me.
Zombie1 Zombie1 is offline
Car: 2010 135i
Default 08-11-2015, 02:06 PM
I'm out of the loop so sorry if this has been answered, is there a company working on swapping a 4L80E transmission over into the n54? Glad to see the car is at least semi working OP.
Car: 2008 135i
Default 08-11-2015, 04:07 PM
Horsepower Barn and AD Engineering I believe.
swat's Avatar
swat swat is offline
Car: 07 335i
Default 08-11-2015, 04:54 PM
Just so the information is here too, what is the 4L80E out of and what's the projected capabilities?
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Race8877's Avatar
Car: BMW 135I
Default 09-07-2015, 09:28 AM
Any news on level 0 ????
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 09-19-2015, 10:19 AM
I doubt they do more extensive work. Level 10 actually does a lot, having spent some time at their shop they do some pretty comprehensive stuff to the valvebody including solenoid work.
The problem lies in the super advanced software that runs our gearboxes. Theres a base line calibration for the solenoids and an adaptation modifier in addition there is at least 4 separate shifting programs. two in drive and two in sport mode.
My previous remarks was based on info that was incorrect as well as an unidentified problem on my car... My throttle body was going bad which was affecting shift quality. Reseting adaptations relieved this making it seem like the software was going out of calibration.
Currently the product isn't perfect every time but I'll be working with them to fix the issues. I have both a full build and a just VB conversion car to work with as well as full dealer tools/tool32.
The owner of this shop REALLY knows transmissions, don't count them out yet. I'll update things as we find solutions.
Car: 2010 135i
Default 09-20-2015, 11:40 AM
That's great and all, but they shouldn't even be selling these upgrades till they get them to actually do what they say they do like hold 700hp+ because they simply do not work...
yournamehere90 yournamehere90 is offline
Car: 2008 535i
Default 09-20-2015, 01:38 PM
4L80E is a General Motors transmission found in many rear drive and 4 wheel drive applications. 4 stands for the number of gears, L for longitudinally mounted engine, 80 for gross vehicle weight capacity, and E for electronic. It was used in the heavy duty pickups and SUVs. Not sure why they would build a 4L80E when there is a newer 6 speed 6L80E that GM has been using for years.
Car: 2007 BMW E90 335i
Default 09-20-2015, 01:55 PM
How did this turn out? I'm thinking of replacing the solenoids and doing the Zip Kit. I'm getting some weird and inconsistent shifts; flare, soft then harsh, etc.
2013 135is DCT Carbon Black
Default 09-21-2015, 11:32 AM
4L80E's were used primarily in GM vehicles, usually the HD versions such at the 2500 series Sierra and Silverado. They were also common in vans and even Jaguar, Aston Martin, and Bentley has used them in some cars.
The 4L80E is essentially a 4-speed version of the famous Turbo 400 (TH400) that is very common in drag racing. As a result they share many common parts and there is a TON of knowledge out there on how to build and upgrade them.
Bone stock they are good for 400-500 rwhp. With just an HD-2 shift kit you can reliably get up to ~600 rwhp. Extra tuning for shift pressures can net even more. A 4L80E with a shift kit and some tuning will go a loooong way.
After that the common upgrades are 300M shafts, billet clutch hubs, rollerized parts, dual-feed direct clutch (which is what the HD-2 kit will accomplish, can also be done internally), etc. In the end they can handle upwards of 1500 rwhp. At this point you're looking at $4000+ to have it professionally built or about half that to do it yourself.
I bought a 4L80E from the local junkyard for $500 with 70K miles and it was in pristine condition when I rebuilt it. Definitely did not need a rebuild but I was upgrading it anyways.
Race8877's Avatar
Car: BMW 135I
Default 09-21-2015, 12:34 PM
Come on guys about time somebody comes out with a full tranny rebuild holding at least
800HP. Reliable HP with out any slippage or ****.
Nniftyfour's Avatar
Car: 335xi
Default 09-21-2015, 01:19 PM
Its REALLY freaking hard with no direct software control.
Car: 2010 135i
Default 09-22-2015, 12:03 PM
I get that I'm not trying to be rude or anything. It's just they know they're upgrades don't work. They continue to sell them and advertise them as a fully working upgrade to unsuspecting customers. How many other car companies build a product and put it into production with out testing said products first? I'm not a tech savvy guy with cars in that sense. I work for my family business doing commercial Roofing. That's like me telling a customer your new roof will last 25 years and with stand 150mph winds, and in reality it ripped off 2 months later with a 50mph gust of wind. I just want someone to find a way to fix this so I can go for big power.
Car: 2008 135i
Default 09-25-2015, 03:32 PM
Oh boy do I have some interesting news!!!
So I spoke with my case worker yesterday and heard Level 10's response to the dispute.
1) They say I've loaded "custom" software onto the transmission. Hahahaha. Really?!? I've somehow cracked the TCU's encryption and written custom software for it? Yea, they're not talking about the Alpina flash (which everyone uses), they're saying I actually made a custom flash for the transmission and that is what is wrong with it. I'm good with software and hardware to a point, but that is well beyond anything I'm capable of.
2) They say they didn't see proof of a 3rd party mechanic validating the problems even though that's what my case worker sent out to them in the first packet. I have a letter from the mechanic that does the work on my car (did my ST install, LSD install, and trans install) validating that the problem is related to the work Level 10 did on the transmission.
Please everyone just do yourself a favor and STAY AWAY FROM LEVEL 10. They are actually making up lies now to try to get out of refunding me for their shoddy work. I'm truly appalled by their actions in this situation.
Nniftyfour's Avatar
Car: 335xi
Default 09-26-2015, 07:34 AM
So I'm guessing the solenoids didn't work?
