montgom626 montgom626 is offline
Car: 2013 BMW 335i xDrive
Default What happens no meth/water with MAP 3? - 07-28-2014, 07:46 AM
I am happily running 50/50 meth/water on Map 3 with JB4 with BMS meth kit I keep the reservoir filled. I do not know what will happen if I run out of meth/water while running Map 3? Damage to engine?
Default 07-28-2014, 08:49 AM
Boost drops as flow drops and the engine isn't damaged.
Default 07-28-2014, 10:20 AM
Thank you. If I refill the tank when I am at the track, will it purge itself of air in the line over time and resume meth/water?
In other words, can I be "lazy" and not have to formally purge the air out of the line?
Russjonesr's Avatar
Car: Bmw e92 335i
Default 07-28-2014, 03:02 PM
I'm sure I have read you must perform 7/5 purge if you run empty
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 07-28-2014, 03:03 PM
Great READ info here
http://www.n54tech.com/forums/showth...ght=prime+meth
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
Default 07-28-2014, 03:25 PM
Thanks. I was hoping I could purge the line of air by just running driving it on MAP 3, and then when the meth/water arrived, the JB4 would recognize it and resume using the meth.
Default 07-28-2014, 05:36 PM
If you run the tank empty you'll get air stuck in the pump. To clear the air you will need to purge it with the line removed from the nozzle for 10 seconds or so.
Default 07-28-2014, 05:51 PM
So, all I need to do is purge the pump? The line can clear itself of air trapped in the line was the pump is purged? Did I get it right?
Default 07-28-2014, 05:52 PM
Yes with the line removed from the nozzle (e.g. no pressure at the pump head) it can then push the air out. It can not push the air out with the nozzle attached.
Default 07-29-2014, 06:26 AM
Darn! I thought the pump (if charged with meth/water) could push any air from the line and through the attached nozzle.
I can get to my pump and run meth/water through it, but in my setup, removing the nozzle is a bit of a chore
What is it about the nozzle that keeps the pump from push air past the nozzle but it can push meth/water?
Default 07-29-2014, 04:55 PM
You can disconnect the line anywhere after the pump. So at the solenoid, right at the pump, at the filter, etc.
Default 07-29-2014, 07:04 PM
Perfect. Thank you so much for your great support!
