skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default For Sale: 18mm BMS Wheel Spacers**NEW** - 06-10-2014, 08:54 PM
SOLD !!
$75 Local pickup
$90 Shipped
Brand New 18MM Spacers : 1 pair = 2 spacers
BMW Wheel Spacers by BMS
(Extended Bolts Included)
Also will include BMS Wheel Pin
From website: $99 + tax + s&h = $125 +
Local pickup close to Sylmar, CA can take this for $75
All others...
...for $90: includes basic s&h anywhere is the USA, not hawaii or puerto rico
Wider Stance = Better Handling & More Aggressive Looks
Easily widen the wheelbase of your BMW with a set of BMS wheel spacers for superior handling while dramatically enhancing the look of your BMW. Wheel spacers push your rims and tires out flush with your wheel well for an instant "fat" aggressive look, better lateral stability and better handling. Also great for creating clearance for aftermarket suspension, big brakes or just making the car look awesome. These super strong BMS spacers are custom designed for your BMW ensuring a perfect vibration free fit. CNC machined from 7075-T6 aluminum alloy and anodized black for protection. There are no markings on the outside edge for a stealth appearance. Each pair of BMS wheel spacers come with aircraft grade 10.9 heat treated extended black wheel bolts.
Quick and easy install. One of the easiest BMW Mods! Dramatically changing the looks of your BMW. The spacer is fitted between the wheel and hub, using the included black longer wheel bolts. Remove wheel, place spacer on the hub and bolt the wheel back up. No Need for a wheel alignment after adding wheel spacers. Individualize your BMW today with BMS wheel spacers. Just bolt on and Go!
Burger Motorsports BMW Wheel Spacers are sold in pairs (2pcs). To do the whole car you must purchase 2 sets. They are hub-centric and all sizes including 10mm have the factory hub on them. Our spacer kits come with the required 10 black longer than factory wheel bolts. No need to search for expensive bolts to match, they're included. Most wheel spacers on the market do not come with the necessary bolts, are made with cheap materials and don't have a lifetime guarantee. Quality, function and piece of mind can be found in every wheel spacer BMS makes. The choice is simple. Spacers are a great, cost effective alternative or addition to lowering the car, new rims, sway bars, and stiffer shocks/springs.
What do the experts recommend for your BMW? Most BMW vehicles can have up to 20mm in the rear and 10mm - 12mm in the front. BMS Recommends 12-15mm rear and 10mm - 12mm front on OEM BMW rims and tires. 15MM, 18MM and 20mm spacers might require slight fender rolling on the rear of some vehicles.
Provide Better Handling by Widening the Wheelbase
Provide A Wider More Aggressive Look and Stance
Specifically Designed for your BMW
Guaranteed for the Life of your Vehicle
10 Super Strong Extended Wheel Bolts Included
Light Weight Anodized Black 7075-T6 Aluminum
Special Pry Tabs on the Back for Easy Removal
1-Piece Spacer with Hubcentric Factory Lip
Strong Solid Design & Appearance
Burger Motorsports BMW Wheel Spacer Kits only fit the following BMW Models.
Only available in 10mm, 12mm, 15mm, 18mm, 20mm thickness
Model Chassis Year
1 Series E81, E82, E87, E88, 1M 2007-2013
1 Series F20*, F21*, F22*, F23*, & F chassis 1M* (non-us) (see below) 2011-2014
2 Series **F22 (see below) 2014-
3 Series F30***, F31***, M3*** (see below) 2012-2014
3 Series E90, E91, M3 2006-2011
3 Series E92, E93, M3 2007-2014
3 Series E46, M3 1998-2006
3 Series E36, M3 1992-1998
4 Series F32, F33, M4 2014-
5 Series F10, M5 2011-2014
5 Series E60, E61, M5 2004-2010
5 Series E34, M5 1988-1996
6 Series F12, F13, & F06 Gran Coupé, M6 2012-2014
6 Series E63, E64, M6 2003-2011
7 Series F01, F02 2009-2014
7 Series E65, E66 2002-2008
7 Series E38 1995-2001
7 Series E32 1987-1994
Z4 E89, Z4M 2009-2014
Z3 Z3, Z3M 1997-2002
Z8 E52 2000-2003
X1 E84 2010-2014
X3 F25 2011-2014
*F20, F21, F22, F23, & F chassis 1M. (non-US) 15mm+ is the smallest thickness spacer this vehicle may use in the rear. Front can fit 10mm and 12mm. This only applies 2012-2014 F20, F21, F22, F23, & F chassis 1M vehicles.
**2014 F22 2 Series. 15mm+ is the smallest thickness spacer this vehicle may use in the rear. Front can fit 10mm and 12mm. This only applies 2014 F22 2 Series.
***2012-2014 F30 and F31 3 Series sedan vehicles only. 15mm+ is the smallest thickness spacer this vehicle may use in the rear. Front can fit 10mm and 12mm. This only applies 2012-2014 F30 and F31 vehicles.
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
hp jnkey's Avatar
hp jnkey hp jnkey is offline
Car: 2008 535i
Default 06-11-2014, 04:39 PM
Is this for 2 spacers or 4 spacers?
A buddy with a 335 might be interested
skysurfer's Avatar
Car: 2008 535i
Default 06-11-2014, 04:58 PM
1 pair = 2 spacers
I will clear it up
2008 BMW 535i
ER CP
E60 DP
skysurfer's Avatar
Car: 2008 535i
Default 06-25-2014, 07:29 PM
Still up for sale
2008 BMW 535i
ER CP
E60 DP
FlaMed FlaMed is offline
Default 07-17-2014, 07:25 PM
Is this still available? Do you take paypal?
skysurfer's Avatar
Car: 2008 535i
Default 07-17-2014, 08:18 PM
Still available
Where are you located?
2008 BMW 535i
ER CP
E60 DP
Default 07-17-2014, 09:02 PM
33547 zip code
Lithia, Florida
skysurfer's Avatar
Car: 2008 535i
Default 07-18-2014, 01:11 AM
I'll pm you
2008 BMW 535i
ER CP
E60 DP
Default 07-18-2014, 04:34 AM
Im sorry, I forgot one important detail. These bolts are black right? I have silver rims. It will look odd with the front still being silver. If its silver, I'll take it, if its black sorry for wasting your time, man.
Default 07-18-2014, 04:56 AM
Disregard the above my rims are silver but my bolts are black. Duh. I'll take it. I'll wait dor your PM.
skysurfer's Avatar
Car: 2008 535i
Default 04-15-2015, 05:53 PM
Still for Sale
Price Lowered
2008 BMW 535i
ER CP
E60 DP
skysurfer's Avatar
Car: 2008 535i
Default 04-19-2015, 11:40 AM
ttt
2008 BMW 535i
ER CP
E60 DP
skysurfer's Avatar
Car: 2008 535i
Default 05-01-2015, 11:41 AM
Price change
2008 BMW 535i
ER CP
E60 DP
Kay Kay is offline
Car: 2009 335I
Default 05-01-2015, 01:35 PM
What's the new price? Please check your messages
Kay Kay is offline
Car: 2009 335I
Default 05-04-2015, 04:47 PM
Check your messages, I would like to send payment, ASAP.
Kay Kay is offline
Car: 2009 335I
Default 05-04-2015, 05:25 PM
Let me know if they are still available.
skysurfer's Avatar
Car: 2008 535i
Default 05-05-2015, 02:52 AM
SOLD !!
2008 BMW 535i
ER CP
E60 DP
