(#176)
m6beast's Avatar
m6beast m6beast is offline
Car: 335i/m6
Default 04-17-2014, 08:48 PM
Originally Posted by m6beast
Damn I was hoping you had a way to get rid if that delimiter, will need the extra mph for that half mile drag race. Anyway once all my stuff comes in ill be needing all the info to start the setup.
Going tomorrow to dyno a base run on 100 octane 5 lb boost increase to compare to meth set up.
Take care
Here is my baseline 93/100 octane mix 5lb boost increase
Dyno graph is in 4th and 5th gear comparisons
After I install meth kit will dyno again and hopefully see some great gains.
Illicit Illicit is offline
Car: 2011 BMW 550xi
Just a quick note to throw in here... I installed the S1 on my 13 M5 6MT, and was able to hit 161 at top of 5th gear, didn't get a chance to hit 6th and had to slow down. I believe the limiter is raised on 6MT's? Or maybe it's not there?
- Igor
m6beast's Avatar
Car: 335i/m6
Default 04-17-2014, 08:56 PM
- Igor
On my GPS compared to my speedometer it's off by -4/-5mph. Mine shows the same around 160+ when the limiter kicks in.
The speedo just reads 3-4mph fast for some reason. But the DME knows you're "really" going 155mph.
badblack550ix's Avatar
badblack550ix badblack550ix is offline
Car: F10 550i Xdrive
Default 04-17-2014, 09:08 PM
damn ive never been at +5
F10 550i xdrive Carbon Black Aluminum BMS Stage 2 WR 11.943 @117.940 Time Slip 421AWHP 467.9 AWTQ MUSTANG DYNO
m6beast's Avatar
Car: 335i/m6
Default 04-18-2014, 02:19 AM
That's the new interface and firmware upload. My older set up was set at 3lbs increase
Default 04-27-2014, 10:15 AM
Customers M5 taking drag record yesterday with an 11.0@128mh! Stage1 tune, exhaust, race gas, and upgraded tires!
hotrod182 hotrod182 is offline
Default 04-27-2014, 10:27 AM
Stock *********?
11 335d M-sport JBD 12.3 @ 110.48
12 LEAF 106 MPGe
08 335i Sedan 11.11 @ 129.43
08 335i Coupe JB3 2.0 11.33 @ 132.77
60-130mph: 6.95 seconds
Bowser330 Bowser330 is offline
N54TECH FTMFW
Car: E92 335i
Default 04-28-2014, 09:53 AM
wow
danzio2020 danzio2020 is offline
Car: E92 335i 6MT
Default 04-28-2014, 12:02 PM
Terry, do you know what tires he was running in the video?
Default 05-03-2014, 12:01 AM
What kind of Challenger was that? Was it the SRT8, big engine,,392 or something?
12 LEAF 106 MPGe
Car: 2011 BMW 550xi
Default 05-03-2014, 11:58 AM
My speedo must be reading 15mph too fast? No way is the 6MT limited at 155.
Default 05-04-2014, 10:10 AM
Yes the speed reads fairly high. I think 4%? With the DCT the limiter kicks in around 6200rpm in 5th gear. Which I've verified is 155mph with a VBOX on the factory tires.
AmarN54 AmarN54 is offline
Car: 11' Z4, 11' M3
Default 05-15-2014, 02:24 AM
Is S2 coming out soon?
And can you use the S2 board on the S63TU on a 14' M5?
Or is it only for the use of meth, otherwise being the same thing?
Thanks. Picking up an M5 in July! Awaiting production to start!
Z4 35is - JB4 and that's it.
Stock time: 12.768 at 108mph.
Tuned time: 11.935 at 116mph.
Default 05-15-2014, 07:37 AM
No S2 is planned for the s63 at this time. You need to use the S2 board if running methanol though. Other than running methanol it's identical to the S1 board.
DrKevM5's Avatar
DrKevM5 DrKevM5 is offline
Car: '13 BMW M5
Default 05-15-2014, 05:46 PM
Terry, what's the minimum octane we can use with setting 3? I've been using setting 2.25 with 93 octane, but if I can raise it a couple of points with octane booster, can I go with the 3 setting "safely"?
Default 05-17-2014, 05:38 PM
If using the older firmware 2.25 is as high as suggested for 93 octane, 2.50 with NOS octane booster, and 3.00 for race gas.
If using newer firmware the values are all completely different of course.
Default 05-18-2014, 11:22 AM
Ordered a set of 19" Forgestar cf10 rims for the M5. 19x9.5 for the front, 19x11 for the rear, as well as some 305/35/19 NT05R drag radials. I'll match up some similar height lighter weight 19" tires for the front once I verify the rims fit OK.
Hoping for 10s when it cools down with traction.
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 05-18-2014, 11:26 AM
Ordered a set of 19" Forgestar cf10 rims for the M5, as well as some 305/35/19 NT05R drag radials for the rear. I'll match up some similar height lighter weight 19" tires for the front once I verify the rims fit, etc.
I have no doubts you'll hit 10's sir Terry
m6beast's Avatar
Car: 335i/m6
Default Methanol verse 100 octane - 05-19-2014, 01:11 PM
Well here's a Dyno run from today. I didn't get to do any back to back runs because I was running 4th gear most of the time today. Car was a little heat soaked but it ran pretty good. Air fuels on my AEM were 12.0 flat to high elevens up top. Noticeable gains were 10 -15 whp and 15-25 wtrq on every pull.
I wanted to run 5th a couple of times and a good cool down but for not raising boost at all I'm impressed.
I knew the car felt stronger in the upper part of the rpm and the Dyno proved it. It truly shows the methanol is keeping things cooler instead of heat soaking when getting in the upper rpm.
This is a 5th gear pull in both runs
One is 50/50 100/93 octane mix at 5lb boost increase
The other one is 50/50 M1 methanol / distilled water mix on pump 93 octane.
Next I will add 100% methanol for a couple of days and see if theres any improvement and re Dyno. After a couple of runs on the Dyno will raise the boost and see if there's any more power to be gained. Car is hauling ass. Maybe go to the track this wed if I can get away.
Default 05-19-2014, 01:17 PM
Very impressive!
m6beast's Avatar
Car: 335i/m6
Default 11.05 1/4 mile runs - 05-22-2014, 06:06 AM
Very impressive!
Yesterday was a hell of a day. Nothing going right from Dyno speed sensor breaking and then getting to the track and the track lights go out. And what a hot humid day 91F and only got down to the high 80's as the night progressed.
Anyway finally got the car to launch great and the only way possible was using burnout mode. Average 60ft was 1.73's and a best of 1.69.
Average runs which we're not that many were 11 flats and a high of 11.2 which I hit the rpm to late.
I feel I should have ran the car longer to adapt before taking it to the track because as I was going home it felt stronger by the minute.
AFs looked great too!
12.2's to high 11's up top
My settings
R888 TOYO DRAG RADIALs 285 35 20
Meth 100% 93 pump
60 additive
Launching the car and finally what worked the best
"Burn out mode"
Just stomp on the gas all the way as soon as you see the second light might have to do it earlier cant remember because the car delays for a sec.
That worked the best as you can see by my 60ft. Now have to find where exactly to hit it for the best reaction time.
Will go again to the Dyno for some accurate numbers and giving time to adapt
Then on to the track again.
Man I was so close I swore I was gonna get my 10's tonight!
Default 05-22-2014, 07:38 AM
So close... Great 60' times!
Be sure to post those slips on M5 post.
m6beast's Avatar
Car: 335i/m6
Default 05-22-2014, 08:06 AM
You know I will so many haters! I was actually getting ready to, and you know how bad I want you to push this car in every way.
thanks again Terry!
rif75's Avatar
rif75 rif75 is offline
Car: Bmw 335i N54 JB4 stage 3 + Bmw M5 F10
Default 05-24-2014, 04:57 AM
Hello Terry,
I just have put the KN filters, I'm going to do a dyno test with octane 100 Shell Power with setting on 4 next week.
I want to do some test with the original power so what setting I have to put on the JB system with the firmware 2014. It will be quicker that remove all the system.
Thanks.
