Tuned1M's Avatar
Tuned1M Tuned1M is offline
Car: AW 1M
Exclamation 2015 M3/M4 revealed! - 12-11-2013, 10:43 AM
Can't wait to see what Terry will be able to pull out of this beast!
431 PS / 431 HP
550Nm, that is 405lb-ft.
0-100 km/h (0-62): 4.1 seconds (DCT)
0-100 km/h (0-62): 4.3 seconds (Manual)
1497kg / 3300lbs (all fluids, 90% fuel, no driver)
1572kg / 3466lbs (plus 68kg driver and 7kg luggage
'16 LBB M2 in production
'11 BMW 1M sold
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 12-11-2013, 11:02 AM
I'll take one
335is DCT
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 12-11-2013, 12:32 PM
Originally Posted by musc
I'll take one
will do the same, M4 with turbo engine,
I always was in love with naturally aspirated engines but perspectives of this turbo engine makes it even more interesting.
2008 335XI(E92) AT/ garrett gtx3582r with jpworks manifold 1.06AR housing/ tial mv-s 38mm wgs(13.5 psi springs)/ tial bov/ fuel it level1 upgrade/ index 12 injectors/ N20 Map sensor/JB4 ST TS BEF with MHD/ Alpina Flash for now.
A418t81's Avatar
A418t81 A418t81 is offline
One tire fire
Car: E92 335, 6MT
Default 12-11-2013, 12:54 PM
Got a deposit down on the M3. Terry, when do we start?
'18 Magnetic Gray Raptor
'19 GT3 RS Weissach
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 12-11-2013, 01:01 PM
What'd you pay?
Arent there still issues cracking the DME on these?
My car has that kind of power now and for more than half the price....I'm hardpressed spending $75k + on one of these....
Taron's Avatar
Car: 2008 BMW 335XI
Default 12-11-2013, 01:07 PM
Originally Posted by iuhutch
What'd you pay?
Inspite of power we get out from our cars i understand that 335 is not an m3
iuhutch's Avatar
Car: 2011 e92 335xi
Default 12-11-2013, 01:23 PM
Agreed but for that price range, there are many other cars i'd consider before an M...
Taron's Avatar
Car: 2008 BMW 335XI
Default 12-11-2013, 01:24 PM
Right, R35 gtr for example ))))
rudypoochris rudypoochris is offline
Default 12-11-2013, 05:02 PM
Engine needs more volume. Its like a marginally higher revving 335i with better everything else. Wonder how much headroom they left on the turbos. The CR is high.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
Default 12-11-2013, 05:06 PM
431 PS / 431 HP
I'll have the first M3 out of Bob Smith.... Got stuck with every possible option. Here is the build sheet.
Default 12-11-2013, 05:15 PM
Seems like it might just be a souped up 335is. But I only know one way to find out...
Stucks Stucks is offline
Default 12-11-2013, 06:01 PM
Those wastegates don't look like they will rattle
Current: 2008 e92 335i coupe.
Hierlevelz Hierlevelz is offline
Car: 09 E90
Default 12-11-2013, 07:34 PM
Maybe one day .
musc's Avatar
Car: 335is DCT
Default 12-11-2013, 08:26 PM
Can't wait until you get a chance to dig into it. I really hope it is more than a 335is just pushed harder from the factory!
335is DCT
BavarianBullet's Avatar
BavarianBullet BavarianBullet is offline
Assistant pedal masher
Car: 335xi
Default 12-11-2013, 09:13 PM
Its a whole new engine with a dry sump and closed deck- a real M engine. That's what you're paying for.
May not sound better but when turbo upgrades start showing up, **** is going to get real.
2011 335xi Sedan 6AT, Premium, CW, Nav, Space Gray, Oyster and black. N55 JB4.
925_335IS 925_335IS is offline
Car: 335IS
Well at least its the right color. I'm curious to see if the DCT will hold up any better then the one in the IS. Ive had to drop down to the race flash from the tweaked e85 flash you made up for me due trans to slipping. I need to get it on the dyno with the e85 flash and see what the numbers are because I'm surprised its slipping that bad with only the stock turbos.
Fernflex Fernflex is offline
Car: E92 335i, E30 327i
Default 12-11-2013, 09:39 PM
Is not a new engine is a N55 but twin turbo and modified.
"The E90 M3 was fitted with the last naturally aspirated BMW M engine - and it was also the last BMW M to use a dedicated M engine developed from scratch. No more. Despite the attention that BMW's performance division dedicated to the new S55 engine, it is still derived from the ubiquitous N55 3.0-liter straight-six."
A message to Terry from BMW
"We don't know what the tuners will do to this car," says an engineer. Getting up there will require extensive engine work: In series production trim, the M3/M4 would theoretically top out at around 185 mph."
Mk7 Gti Dsg: 298whp
E30 332i: Race Car.
musc's Avatar
Car: 335is DCT
Default 12-11-2013, 09:48 PM
Still my concern moving forward. How many miles you at?
This is my fear. I really hope it is not just an N55 pushed to it limit with very little room for more power from the likes of BMS.
335is DCT
Default 12-11-2013, 10:06 PM
Yes I expect the trans, etc, will be an issue. Expecting the new M3 platform to make more power than say the N54 platform w/ RB turbos might not be very realistic. But you never know.
sA x sKy sA x sKy is offline
Car: 2011 E92 335xi
Default 12-11-2013, 10:39 PM
That's why you wait for the new M3 platform to have RB turbos of its' own
AWE Non-Res Exhaust | AWE CF Intake | AWE ColdFront | ER DP | ER Chargepipes | JB4 Stage 3 | Custom SS Methanol | Swift Springs | TPG/DSS 1200hp Axles | Dodson Superstock DCT Clutch | PURE Stage 2 Hi-Flo
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 12-11-2013, 11:15 PM
I'll take one
I'll take ten
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | *****Performance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
JonMartin's Avatar
JonMartin JonMartin is offline
huh?
Car: German car(S)
Default 12-11-2013, 11:29 PM
Hell has frozen over! Congrats
2014 CLS 550 Magno Cashmere White
musc's Avatar
Car: 335is DCT
Default 12-11-2013, 11:39 PM
Could make a good vanity plate for Terry's M3
335is DCT
coolbho3k's Avatar
Car: BMW 335xi
Default 12-12-2013, 12:16 AM
:l ol
Miller335 Miller335 is offline
Car: 2007 E92
Default 12-12-2013, 05:52 AM
That's my take on it as well.
