jftechperformance's Avatar
jftechperformance jftechperformance is offline
Car: bmw 135i
Default map 2 better than map 5 on dyno - 06-05-2013, 05:00 PM
this is 2 log , map 5 at 16.5psi, and map 2 at 14 psi.
I use 94 oct with octane boost ,,jb4 ******** exaust.etc...
map 2 is better....
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
black wheel 18 X 8.0
Default 06-05-2013, 05:08 PM
Often less is more. Map5 will adapt down after addl runs I suspect.
Car: bmw 135i
Default 06-06-2013, 04:12 AM
map 5 adapt cause pcm got knock and it lower the timing?
how map 4 is not adapt ,we can t tell pcm to not adjust timing? I think.
can you create a knock count on data we log? it nice to see what realy happen.
can I change value on user setting to get better result in map 5 , not 16.5 psi but with 9 or 7 timing like you see in my log, I have probably 96 oct, why it down at 7 timing?
thanks
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 06-06-2013, 11:23 AM
map 5 will adapt down as terry said...
e92
Car: bmw 135i
Default 06-06-2013, 01:16 PM
? Not good explanation .i know that . Want to now more...
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
Default 06-06-2013, 01:20 PM
The field called "avg ign" is used to trend the closest thing we have to a "knock count". The higher the number the lower your advance is from the max targets and the less boost map 5 runs.
Car: bmw 135i
Default 06-06-2013, 01:22 PM
Better
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 06-06-2013, 02:16 PM
virtual dyno is hardly scientific. take the car to a real dyno and compare.
E90 LCI N54 6AT
Car: bmw 135i
Default 06-06-2013, 02:39 PM
trust me same place same temp same wot etc... , its normal with less boost but with better timing give more horsepower....
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 06-06-2013, 02:59 PM
+1
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
JonMartin's Avatar
JonMartin JonMartin is offline
huh?
Car: German car(S)
Default 06-06-2013, 03:25 PM
WTF is a virtual dyno? Is that like cyber sex?
2014 CLS 550 Magno Cashmere White
skysurfer's Avatar
Car: 2008 535i
Default 06-06-2013, 03:34 PM
LMAO !!
Good one !!
2008 BMW 535i
ER CP
E60 DP
mmmcookies335i's Avatar
mmmcookies335i mmmcookies335i is offline
Car: 335 M-sport
Default 06-07-2013, 09:36 AM
2009 335i M-sport--G5 ISO--AR 3" ******* DP's--BMS DCI--VRSF 7" FMIC--BMS Charge pipe--Eibach Pro/Koni yellow--M3 arms all around--BMW SSK--LUX V4--Michelin PSS--Spec Stage 2+ W/SMFW--Walbro 255LPFP
Hellraiserharris's Avatar
Hellraiserharris Hellraiserharris is offline
Car: 14' 435i
Default 06-07-2013, 02:17 PM
LOL. That's some funny **** right there.
14' 435i. M-Sport, JB4 Stage 2, BMS Intake, more to come
Car: bmw 135i
Default 06-07-2013, 04:31 PM
lol u don t know nothing about car and tuning if you don t know that, 300 000 people use that program.. and if you have nothing better to tell just shut up..
we ask question here about performance mapping , so let post clean..
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
trebila's Avatar
trebila trebila is offline
Default 06-08-2013, 12:32 AM
I also use this software, very helpfull.
First I've done a real dyno run, then I've calibrated the virtual dyno software in order to have the same numbers, and then I test each mods by running the virtual dyno, always on the same road.
I'll test Map 2 and Map7 to compare to my map5 curves...
MasterWang MasterWang is offline
Car: 2007 335i e92
Default 06-08-2013, 09:56 AM
Virtual Dyno was proven to be really accurate actually (Real Dyno compared to VD)
You just have to have to make sure all the settings are right (Weight, Tire Diameter, etc)
I actually know the creator of the program and he keeps asking me to race his gt500!
Super nice guy who is always willing to help out if you have questions about the program.
Blown-WK Blown-WK is offline
Car: 08 335i
Default 06-09-2013, 01:39 PM
I've found map 2 to run stronger than map 5. If its pulling timing it's not making as much power. Put some race gas in it and run map 7. You'll notice it pulls damn good.
-CHRIS-
08 335i - BMS DP's, DCI, JB4
06 Jeep SRT8- Inferno Red- Stage 6 Single Turbo stock block build 710/664 at 10psi
10.61 @ 132
Tuned by JerseyBoy and Terrorizing the Streets!
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 06-10-2013, 02:52 PM
So, to jump in here and make sure I understand the feedback from Terry/others:
Map 5 may have made less power than Map 2 on the dyno because it had not had time to "learn" the fuel/temp/etc, and would eventually have adjusted the variable parameter settings down to the same settings that are "hard coded" into Map 2. And that if Map 5 had gotten a few more 3rd/4th gear full pulls, it would have made similar power to map 2 (11 whp/34 tq more)?
Blown-WK, can you elaborate on finding "map 2 to run stronger than map 5", and describe your steps/method? how much time did map 5 have to "learn" the fuel/atmospheric in your car prior to your measurements? Did you try map 5 first, and then map 2? vice versa?
Car: bmw 135i
Default 06-10-2013, 06:38 PM
map 5 try higher boost so the timing is lower, we need timing for horsepower
17 psi at 8 degree of timing give less power than 13 psi at 12 degree...
learning not help if we do 10 log at map 5
it won t adjust better....
we need boost and timing for performance, need 17 psi but with 12-13-14 of timing
sorry I know my English suck
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
hkninja's Avatar
hkninja hkninja is offline
Car: 535i 6MT
Default 06-10-2013, 08:43 PM
I felt the same way. I was trying out Map2 vs Map5 i think Map2 pull stronger! It was very humid and rainy today at 80's deg. I guess the condition gotta do something with it?
2008 535i 6MT * JB4 G5 ISO * Luke performance flash * E40 * BMS 100% Meth * AR meowless DP * ETS FMIC * BMS OCC * BMS DCI * ER chargepipe * HKS bov * CDV deleted * Ksport coilovers * UUC short shift kit * AC schnitzer rear spolier *
JonMartin's Avatar
huh?
Car: German car(S)
Default 06-10-2013, 09:56 PM
Don't cry dude its not that serious have fun cyber sexin.
trebila's Avatar
Default 06-13-2013, 01:18 PM
I've made few virtual dynos with first Map5 (blue) and then 2 runs with Map2 (red and green). same road, same time, same conditions.
pretty big difference, no ?
and I can feel it too. the Map 5 is muuuuuch more powerfull than Map2.
I'm running 50% E85.
Car: bmw 135i
Default 06-13-2013, 01:41 PM
Wow 14psi at 6000 rpm and more .map n54 is really better than n55 tune
Can you post your log? To see timing
BMW 135i 2012
n55 stage 2 jb4
exaust bms
charge pipe
k&n
trebila's Avatar
Default 06-13-2013, 02:09 PM
for the map5 tune, I've set max boost at 17 psi instead of 18, because of the 50% E85.
with those high IATs (OEM intercooler, still), the boost is lower than with more fresh air.
