Default Updated 335is dyno - 05-22-2013, 05:13 PM
Had a chance to dyno a 335is today. He's running JB4 G5 (ISO_21 firmware), a new backend flash we made a couple weeks ago for DCT cars, BMS *********, BMS DCI, BMS CP, ETS IC, E40, and a BMS meth kit. All runs were done on map 7 which targets 18.5psi peak tapering to 14.5psi at redline. Runs were done in 5th gear and temps were in the high 70s.
Car performed flawlessly on the dyno and set a new N54 stock turbo power record. It's a touch over advanced for E40 @ ~6300rpm but the owner plans to run E50 and shifts around 6000rpm anyway, so we decided to leave it as is for now. We'll collect some additional road logs for further evaluation. The car is an absolute beast and he reports no DCT trans slippage.
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 05-22-2013, 05:23 PM
Nice #'s!
Marv85 Marv85 is offline
Car: '07 335i MT
Default 05-22-2013, 06:26 PM
Terry why is the boost low? I'd assume with E40 and meth, you can run 20psi midrange.
SOLD --'07 E90 335i, PTF COBB E50, HFS4, ER CP, ETS 7", AA **, Exhaust, DCI, ACT, Nitto Nt555
SOLD -- '10 E92 335i M, 6MT COBB v3, ER IC, ER CP, VRSF **, Fuel-it st2, Mfactory LSD, powerflex subrframe bushings
JonMartin's Avatar
JonMartin JonMartin is offline
huh?
Car: German car(S)
Default 05-22-2013, 07:00 PM
Nice whats different on iso 21?
2014 CLS 550 Magno Cashmere White
1///M's Avatar
1///M 1///M is offline
Car: BMW 1M
Default 05-23-2013, 12:47 AM
why would you run Map 7, when you have meth or was meth flowing on all maps ?
Is Map 7 with meth better than map three with a 70% additive?
RHD Top Mount ST
mdyates mdyates is offline
Default 05-23-2013, 06:23 AM
Nice work!!
Default 05-23-2013, 08:41 AM
There is plenty more boost on tap down low, but since this is a DCT trans, we decided to keep it a bit on the "conservative" side.
Default 05-23-2013, 08:42 AM
Basically raised the duty cycle limit for people who are pushing stock turbos to their limit.
Default 05-23-2013, 08:44 AM
He's running E50 and our flash so can run map 7 without meth. And instead just uses the meth for cooling. So no safety is required. Map 7 happens to very nicely match the factory turbo power curve. It's 18.5psi tapering to 14.5psi at redline.
Map 3 has less taper and more boost down low. So in theory has more power & torque potential. But since we're turbo limited basically map 7 & map 3 + 60-70 additive tend to perform about the same.
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default turbos - 05-23-2013, 10:54 AM
Could you do something similar for someone running Rb's? Meth doesn't give me the warm fuzzies. I do have e85 on tap and would like to run meth as a cooling factor. I wld like to see 480-490whp range and your backend flash with the 455 walbro? Rb install underway right now
Default 05-23-2013, 11:00 AM
Sure just do a custom map 6, set meth additive to 0, and then meth will turn on while targeting your map 6 values. Something like 19psi tapering to 17psi at redline should do it.
07tundra's Avatar
Car: a slow one
Default 05-23-2013, 11:12 AM
So 480-490 is possible then without having to tune for the meth?
Default 05-23-2013, 08:04 PM
You can tune for E85 only to around 480rw, then just use the meth on top for cooling and fuel system support.
///ADMAN ///ADMAN is offline
Car: 2013 BMW 335is
Default 05-24-2013, 09:56 AM
Subscribed...
2013 BMW 335is Convertible
Default 05-24-2013, 10:10 AM
Originally Posted by ///ADMAN
Subscribed...
You are a good candidate for our back end flash. Since you are using E85 or race gas we can ramp up those advance targets, firm up the DCT, and probably add 30hp in the process.
Car: 2013 BMW 335is
Default 05-24-2013, 02:11 PM
I'm in
I am actually on the way to my car RIGHT NOW to update the hex.
Anything else I need to do? I saw on the other thread to check the FutureUse setting.
And, I assume I can still run the fixed MAP6 you gave me. My car likes it with the E85.
Default 05-24-2013, 02:16 PM
I'm in
You're thinking of the JB4 firmware... The back end flash is something else all together. Normally it's reserved for large turbo and heavy E85 cars but the 335is cars running E85 or race gas mixtures also greatly benefit from it.
Default 09-14-2013, 06:43 AM
What tire size and brand is he running?
2013 335iS DCT, Alpine/Saddle
JB4, BMS Flash, DCI, BMS Dp's, Inline
*RECORD 1/4
11.5 @119 mph*
Stucks Stucks is offline
Default 09-15-2013, 12:13 AM
Toyo R888's.
http://toyotires.com/tire/pattern/pr...petition-tires
Current: 2008 e92 335i coupe.
