ivyqsixty ivyqsixty is offline
Car: Infiniti Q60
Default Map 6 Help - 08-01-2019, 02:45 PM
Trying to run the best setup but I donít see anyone talking about the non red sport setups...anyone care to share their setup I have a 2018 luxe. Thanks in advance!
Car: q50
Default 08-01-2019, 04:36 PM
Trial and error, read logs and repeat. Tryataper up to 6psi and drop it down quick above 5k.
Q50 Premium RWD
BMS JB4 w/ FW & WMI
Post turbo stuff lol, Y pipe, Mid pipe
BMS HE
Car: Infiniti Q60
Default 08-01-2019, 05:43 PM
Care to give me kinda of an example of how to lay it out. Sorry so new to all of this.
Car: q50
Default 08-01-2019, 06:01 PM
Ramp up from 2000 rpms adding +2 psi to +6 at 5000 Rpms and then drop back in 2 psi increments above 5000.
Q50 Premium RWD
BMS JB4 w/ FW & WMI
BMS HE
Default 08-01-2019, 07:17 PM
Any tuning changes should be based on data from the car, adding boost in areas where the logs tell you it's safe enough to do so.
Car: Infiniti Q60
Default 08-02-2019, 12:25 PM
1500:3.0
2000:4.5
2500:5.0
3000:5.0
3500:5.0
4000:5.0
4500:5.0
5000:5.0
5500:5.0
6500:3.0
7000:1.5
This is what im running currently. What should my boost safety and default wastegate position be on? I found this map 6 going through that big thread so just wanna make sure I have everything right. Thanks in advance!
PACE2525 PACE2525 is offline
Car: 2017 Q60 RED SPORT AWD
Default 09-19-2019, 07:50 PM
Hi Terry,
What should the BOOST SAFETY setting be set in Map 6?
Also, if it is set incorrectly on the LOW end will it screw up the JB4 performance while accelerating?
Thanks.
