Roi354 Roi354 is offline
Car: 2009 335i
Default Map 4 after meth install - 09-23-2018, 12:13 AM
UK spec '09 N54 335i - JB4 G5, MHD BEF, DCI, OCC, no kitties in d-ps, BMS meth (50/50) w 1xCM5
Car still runs well on map 2 but any attempt to WOT on map 3 and it'll kick back to 4 with a double blink. Boost safety still set to 18psi, could this be the reason? Still on stock TMAP so maybe I should look to change this for 3.5Bar?
Thanks for any help,
Rob
Default 09-24-2018, 05:55 AM
Got a log for me to look at?
Car: 2009 335i
Default 10-04-2018, 06:05 AM
Hi Payam, sorry for the delay (right time, right road, right weather, etc).
Here's some logs i just did. 1st run was ok, 2nd gave me the problem, 3rd was good with the boost safety increased.
Haynpunch's Avatar
Car: 07 E90 335i
Default 10-04-2018, 07:16 AM
Rob
https://www.n54tech.com/forums/showthread.php?t=10605 POST #3
-you pretty much answered your own question... look under last safety in your log it'll tell you what kicked you into safety (map 4)
-enable 6cyl timing logging
http://www.burgertuning.com/JB4_upgrades.html
-if you plan to target boost over 20 psi you should look into getting at upgraded tmap
