(#526)
AzM750 AzM750 is offline
Car: 2011 750i M sport
Default 10-10-2020, 01:48 PM
Originally Posted by SINasTER
A 3.5bar TMAP would be useless with stock turbos, you would need to upgrade them. If you think you have problems with your TMAPs, just replace them eith oem
How exactly would it be useless? Our stock ones max out at 20 and that means I canít go up in boost. Iím already hitting 17-20psi depending on the air temp outside so once I put my ********* on and 5 gallons of e85 yes it will definitely help me get beyond the point of throwing codes or whatever difficulties you guys go through. Iím also doing a tune on top of the jb4 so I will be doing a setup that holds a constant 24psi
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Default 10-10-2020, 02:35 PM
I donít know what cheap chinese TMAPs youíre running but I presently go up to 25psi on a heatsync stage 2 tune without issues.
BMW 550 M-Sport xDrive 2011
HPE DME Stage 2 tune
JB4 backend flash
Custom valved exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Firestone Firehawk Indy 500 235/40R19
Front: Firestone Firehawk Indy 500 285/35R19
Default 12-28-2020, 09:24 PM
Just an FYI for people like me who were under the impression we needed 3.5 bar tmaps to go beyond 20psi. i have a vivid racing stage 2 flash with the jb4 along with VRSF ************ *********s ARM cold air intake N63intakes oil cooler valve ngk 2 step colder plugs this is on a n63 NON TU...on map 0 I’m running 17psi map 1 22-23 and map 2 23-24psi...so no need to add these unless you are turbo swapped
Default 12-28-2020, 09:49 PM
You absolutely need 3.5bar sensors to safely run over 20psi. Otherwise, you're just asking to smoke your motor due to out of control boost.
Default 12-28-2020, 09:52 PM
Should I be seeing boost spikes and huge variations? It seems to hold steady and the logs look good lol...guess I’ll be ordering the 3.5 bar tonight based off your response lol
Default 12-29-2020, 11:38 AM
Post the log if you want tuning advice on it.
Wht550Jersey Wht550Jersey is offline
Car: 11 550i
Default 01-16-2021, 02:51 PM
Map 2 log . How does it look . Thanks
Default 01-17-2021, 02:06 PM
Do you have an ECU flash also?
Car: 11 550i
Talking 01-17-2021, 02:22 PM
Not yet . Had some kinks I been working out , hopefully all good now
11 550i Rwd
Badblk intakes , 3.5 tmaps , bms JB4 & pedal tuner, vrsf *********, custom X pipe and exhaust .
Car: 11 550i
Default 01-18-2021, 09:31 AM
Posted a log for you . Thanks
11 550i Rwd
Newn63 Newn63 is offline
Car: 2012 550I M Sport
Default Backend tune - 02-04-2021, 09:27 AM
Can you guys recommend some back end tunes for the n63? Thanks
Default 02-04-2021, 01:28 PM
Looks normal to me for map2!
Default 02-04-2021, 01:48 PM
Terry at wot around 120+mph I always get a drivetrain malfunction this has been happening since I got my jb4 I just havenít had time to address the issue could you please look at my tune 2 log and give me an idea of what I have to do to fix this issue? Thank you
2012 550i all stock just a bms pedal tuner
Yo_Holle Yo_Holle is offline
Car: F15 X5 E46 M3
Default 03-07-2021, 12:56 PM
Hello
I have a 2015 X5 xDrive50i with the n63tu and thinking about getting JB4
What type connector will i need?
Does it still having steering wheel controls like older versions? or will i just have to use the app?
Car: F15 X5 E46 M3
Default 03-07-2021, 01:04 PM
Do I go from the pics on this page for choosing the connectors?
https://burgertuning.com/collections...cts/n63-stage1
Also for the BCM connections do I purchase a BCM or is that made to the car?
Alexe70 Alexe70 is offline
Car: 2013 x5 50i
Default 03-20-2021, 07:41 PM
Terry can I get some help. I have downloaded new firmware for my ,13 x5 50i. But nothing on app works but the boost gauge. And when in map 1 or 2 boost doesn't get over 9 psi and runs sluggish. Is something wrong with my jb4? Advice?
BMW750i/\/\'s Avatar
BMW750i/\/\ BMW750i/\/\ is offline
Car: 2011 BMW 750i M package
Default 06-29-2021, 05:39 PM
quick question... i have a 2011 BMW 750i M sport with down ***** , cold air intake and jb4 and i just got the 3.5 tmap sensors and adapters but i installed them and i got the check engine light, so my question is do I have to change anything in the JB4 ??
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 06-29-2021, 08:55 PM
Yes. There’s a setting for TMAP. 0 is stock, 1 is 3.5 BAR and 2 is 4 BAR.
Mike Levy
Smile 06-30-2021, 03:31 AM
thanks Mike_L
Default 06-30-2021, 03:33 AM
ohh one more ? ... do I need to change the boost level from 20 psi or does the JB4 do that automatically?
Default 06-30-2021, 06:51 AM
What map are you going to run map 6? Iím pretty experienced with this ECU and non tu setup. If you are looking to put in some work on the streets you will want to get a real flash from heatsync-performance euro, along with the jb4 stacked. Without getting into detail too much the jb4 is simply better off left in map 2 until then. I ran 23k miles on a super aggressive tune in a 2011 750i and ran a personal best on 11.89 and a consistent 11.95-12.00 any day of the week at any red light on dragy. But there are plenty of customers who simply got some stage 1 flash or some jb4 and ********* and have blown engines. A remap of this engine from a legit place will ensure you lay the smack down and itís lasts. I believe I had the fastest 7 series non tu RWD car in existence you can always text me if you got questions 346-219-3863 as there is way more to this and I could help you way more in depthÖ Iím
Default 06-30-2021, 06:57 AM
^^^to my above comment I am not a tuner I am simply an experienced owner and my own mechanic so I’m not claiming **** besides that lol don’t send me logs lol
Default 06-30-2021, 01:25 PM
Not clear what you're asking but the boost safety setting should be set 2-3psi above the highest intended boost target. So it only trips the safety if boost is going higher than you expect.
Default 07-02-2021, 06:39 AM
Thanks AzM750 ...i'll definitely hit you up when i have more ? ...
