(#826)
evanaswan evanaswan is offline
Car: x6m F96
Default EWG error charging pressure F96 comp 2021 - 03-30-2021, 05:20 PM
I ran non EWG for a few months. Just connected them. Ran for 5 days no issues. Then hard on the throttle today and drive train malfunction, and this code. 120719 Charging pressure control: Charging pressure too high dme8ff_l Digital Engine Electronics 2.
Does this mean to much boost?? I haven't changed any settings.
I'm running the latest version of firmware Version 11.
2021 F96 93 high grade octane. Map 2. I will log in the morning Map 0, Map 1, Map 2, Map 3. See where the issue is. Unless this is a know problem or a quick tweak in the Jb4 settings can be done to remedy.
Car: x6m F96
Default 03-30-2021, 05:21 PM
Yes. I also have Bimmer Link app on iphone. It reads and clears codes.
Drivenagain Drivenagain is offline
Car: X5M
Default 03-31-2021, 10:31 AM
Oh cool Iíll look into that. I may have to remove and take in to dealership as Iím stuck in the Reduced Power mode and canít seem to clear it. Not how I wanted to make my first trip to the dealership but Iím at a loss as to what to do.
Default 04-01-2021, 10:40 AM
120719 is a known false alarm fault that rears head from time to time. It just means we had boost at partial throttle a little higher than expected. It seems to be EWG related, you could disable EWG by turning on options bit5 to confirm/verify.
As to the real fix waiting for more logs from people who are able to easily recreate to continue to track down the cause.
Car: X5M
Default 04-01-2021, 11:19 AM
Update: Terry said to check connections possible know EWG issue. Uninstalled the JB4, reinstalled and triple checked all connections. The CEL cleared right away. I then drove around for a bit, then filled up with a fresh tank of E30. Switched to Map 3 and ran a 6.84 60-130 Extremely impressed with E30/Intake/Map 3
Happy Customer.
EDIT: Terry Ill get you new logs.
Car: x6m F96
Default EWG error - 04-03-2021, 08:16 AM
Hi Terry,
Cleared codes via app. I can get it to error typically within a 10 minute hard drive. Seems to cut power when drive train malfunction pops up. Then after a minute feels like I have full power again like it never happened even though the error is still present on the idrive screen.
I ran some logs. I can do more and hopefully we can see the trigger for the fault. I don't want to disable EWG. the power is addicting. For sure a difference.
Default 04-03-2021, 03:30 PM
Happy Customer.
Default 04-03-2021, 03:31 PM
Hi Terry,
I don't check this forum enough for real time tech support so just email me for assistance!
mtechguy90 mtechguy90 is offline
Car: 335
Default 04-30-2021, 05:52 AM
Who is running dp with a Jb4? If so have you seen a bump in performance ? Thanks !
Morebs4me Morebs4me is offline
Car: 2013 550i m-sport
Default 05-02-2021, 04:05 PM
No lol but I'll check with a draggy soon and see
BigChiefM5comp BigChiefM5comp is offline
Car: 2020 M5 competition
Default 05-17-2021, 07:39 PM
got the car dynode the other day with three maps. did map0, Map1, and Map3 since Map 2 is always over boosting. Map0- 601whp 553wtq map1- 596whp 607wtq and Map3- 648whp 631wtq. surprised map1 did less hp over the stock tune. been having a lot of issues lately and cant seem to get it dialed in. ever since I plugged the waste gate sensors in I've been having the issues. map2 hits 33-34lbs of boost and shuts the jb4 off. Any input from anyone.
Default 05-17-2021, 07:42 PM
ive had ********* on mine and its honestly tough to say if its had a lot of gains. map3 for me on good 93 my car made 648whp and 631wtq. Map2 I cant even run cause car over boost to 33-34lbs and shuts the jb4 off completely
Default 05-17-2021, 07:43 PM
Send terry logs but did you try latest software and lowering ff slightly? What is ff at
JK-M5's Avatar
JK-M5 JK-M5 is offline
Car: F90 M5
Default 05-25-2021, 12:50 PM
My Car just did it, same false alarm and its been on Map 0 for a while so be founded as to why, i could understand maybe a selected Map fault, Also why can't we switch between Maps on the fly now, JB4 not really doing it for me at the moment guys!
Default 05-28-2021, 08:20 AM
I checked my FF on map2 its at 82. seems high other maps its at 50.
Default 05-28-2021, 10:19 AM
FF is dynamic and will learn over time based on a number of variables.
Default 05-30-2021, 05:48 PM
On the F90 map switching is done via the app and can be done on the fly.
Default 05-30-2021, 05:49 PM
Minimal gains, and you'll have a CEL and odor, so I can't say we suggest them.
Car: x6m F96
Default 06-09-2021, 07:06 AM
Noticed a new firmware update HeX4
So ran the car and the dreaded code pop up. Same one on new firmware. Map 2 feels strong however.
Default 06-12-2021, 01:46 PM
If anyone is having an easy to recreate "boost too high" sort of fault with the latest firmware versions that goes away when options bit5 is turned on to disable EWG, and is will to test a few things out, drop me an email. First thing I want to do is test some older firmware versions to see when this bug cropped up exactly so we can stomp it out! terry@burgertuning.com
