(#4401)
RandyNester RandyNester is offline
Car: 2018 Q60 3.0
Default 07-03-2019, 12:00 PM
Originally Posted by 05g356mtt
From my very very limited experience with JB4 lol, other than pushing turbo's beyond recommended limit, this looks clean. what fuel are you on?
We basically have the same mods and im on 93 and I noticed my car's logs are much cleaner consistentlyif i go +3.5 max throughout 1500-7000. I've ran Map 2/Map 6 with +4,,+4.5,+5 tapered and while there were clean runs, the clean runs weren't as consistent.
Megan LDP's being installed today, a member suggested its better to let the turbo's breathe better than up the boost past it's efficiency zone which makes sense to me
I tried 0.5 higher
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Rev9 Flowmaxx Axle-Back Exhaust
Megan LDP
Car: q50
Default 07-04-2019, 12:36 PM
Still offline?
Yep, had to ship it all back to BMS. They said they'd take a look and replace anything that needed it. Hoping to get back in action shortly. Concerned maybe something with the last app update did something but pretty sure I connected after the update without issue.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-04-2019, 01:18 PM
That's a bummer. I know driving around stock must feel like driving a 2.0 right now
2019 Q50 Luxe RWD *JB4 with Fuel Wires*BMS Intakes*AMS Downers*Frozen Boost 101*Megan Y Pipe
12.64 @113mph
0-60 4.46
Car: q50
Default 07-04-2019, 01:30 PM
It's surprisingly not bad since I still hit ~ 11 psi with no map. Think it's the ******* ********* and y/mid.
indrik indrik is offline
Car: Q50
Default 07-05-2019, 03:24 PM
Anyone able to give me some insight into these? My main concern is the boost reading on map 1 and 2 (and every other map). The module reads and logs actual in map 0 but the second I switch into adding boost it seems to think it is capping it at 5psi or so. Or at least much lower than the goal of the maps. Currently have an E25~ mix in the tank.
I also feel a hiccup around 3k that I'm wary of but I'm not sure whats going on with that.
Default 07-05-2019, 05:02 PM
Yes something isn't working here. What mods? Ever touched the head exchanger?
Car: Q50
Default 07-05-2019, 05:06 PM
Completely stock 18 except muffler delete, and flex fuel sensor
Default 07-05-2019, 08:13 PM
Is it a new install that has never worked. Or was it working fine for some time then suddenly acting up?
Car: Q50
Default 07-05-2019, 08:47 PM
its been installed about 3 weeks and all of my auto logs tell a similar story from what I can tell as my planned logs.
g0t2bmiirii's Avatar
Default 07-06-2019, 07:16 AM
Got 2 short logs to show You Terry.
The more recent one (today) was on sport mode, 80 degrees, from 60mph to 100-105mph with low fuel light on. The other one i forgot
-LDP
-Megan Racing Y-Pipe
-TopSpeedPro Mid-Pipe (resonated) exhaust
-BMS Cold Air Intake
-JB4 (map 6) w/Fuel Wires (93oct)
karthikloyola karthikloyola is offline
Car: q50
Default 07-06-2019, 07:28 PM
Hi Terry, Need advise.
I own a 2017 3.0T premium and recently bought a JB4. I use 93 gas and use map 6 with the attached boost levels. My car is completely stock. Temp around 90s
Attached the log from my recent run. Need your advise on the graph and also if the map 6 that i'm running is good for premium.
PRQ50 PRQ50 is offline
Car: Q50
Default Blow off valves - 07-06-2019, 09:48 PM
Not sure if this has been discussed before on here, are these a good add on with JB4?
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Q50Philly's Avatar
Q50Philly Q50Philly is offline
Car: 2018 Infiniti Q50 Red Sport
Default Location side of AFR (#1) vs AFR2 - 07-07-2019, 11:54 AM
Hi Folks - After installing fuels wires, enabled Future UseD bit 0, I have my first CEL and AFR(#1) reading is stuck at 25.5...AFR2 normal at 14.7 on idle. I checked posi-taps and pin positions (thanks to tips from Ddnspider and Jrobohm!) and they are installed per YouTube install video).
Do you know which side AFR(#1) vs AFR2 is located?
2018 Q50 Red Sport AWD
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
AMS Red Alpha Cold Air Intakes
Megan Racing LDP
Tanabe Y-Pipe
Mishimoto Oil Catch Can
Mishimoto Heat Exchanger
Default 07-07-2019, 01:40 PM
AFR1 is the driver side IIRC, connector must be unplugged or something.
Q50Philly's Avatar
Default 07-07-2019, 06:23 PM
Thanks Terry!
BMS JB4 w/Map 1 - 8
BMS Fuel Wires
BMS WMI Kit
Megan Racing LDP
Tanabe Y-Pipe
Car: q50
Default 07-07-2019, 08:43 PM
Hi Terry. Need your review of my logs. Iím new to jb4. Iím seeing AFRs close to 25. Please let me know what needs to be done.
Default 07-07-2019, 09:26 PM
Hi Terry. Need your review of my logs. I’m new to jb4. I’m seeing AFRs close to 25. Please let me know what needs to be done.
AFR looks normal other than the start. Are you brake boosting or something as fueling appears to be in open loop mode.
Let's see a log on map1 and map2 for comparison.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-10-2019, 08:24 AM
Hey guys, what gauge are you using to monitor your charge air temps? IAT? Trans Temp? Basically I am trying to make sure my Heat Exchanger is actually working but not sure which gauge is monitoring the key data to ensure it is.
12.64 @113mph
0-60 4.46
Car: Q50
Default 07-10-2019, 10:21 AM
Trans temp
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-10-2019, 10:26 AM
Originally Posted by PRQ50
Trans temp
Gracias
12.64 @113mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 07-10-2019, 10:39 AM
Gracias
My AMS HE typically is +15 over ambient - unless I have been pushing it (more so now that I have my BMS WMI Kit dialed in... )
BMS WMI
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
Car: Q50
Default 07-10-2019, 03:23 PM
My frozen boost type 101 runs about 10F over ambient (dashboard indicator) not IAT.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-10-2019, 03:32 PM
Same with my FB101. I have Oil Temp, Trans Temp and IAT gauges selected along with Map AFR and Boost. Trans Temp has always been 5-10 degrees more than the outside temperature
12.64 @113mph
0-60 4.46
Car: Infiniti Q50 RS400
Default 07-12-2019, 12:30 PM
Anybody know where I can find info how to connect the fuel it sensor to the Jb4 module? Thinking of pulling the trigger on the Fuel-It/BMS kit. TY
Default 07-12-2019, 04:00 PM
It's in their install guide, just plugs in like the FSB. Once you have it generally installed email me for a firmware update that is needed for both meth & flex fuel sensor inputs.
