brandon818 brandon818 is offline
Car: 2012 335is
Default Seeking custom map 6 - 04-25-2019, 11:25 PM
So I have a 335is dct, full bolt on and e85. I currently run map 5 (autotuning map) however I'm seeking more power and would like to have a map 6. Is there anyone that can do this that you guys would recommend? or is this something I could do by myself without blowing up my car lol. Thanks
FBO 335is
Default 04-25-2019, 11:31 PM
Post a log of your map 5
We can take a look / help u dial in a map 6 if you are using our OTS BEF
Car: 2012 335is
Default 04-27-2019, 01:01 AM
here's a map 5 pull on e60
FBO 335is
Default 04-27-2019, 06:53 AM
How old are your turbos?
Your undertarget up top, FF is maxed as is wgdc up top- it looks like you have a leak.
Will went to get that resolved before going to a map 6
Car: 2012 335is
Default 04-27-2019, 10:19 AM
70k miles on the turbos. Should I take the car in to mechanic to check for boost leak? or do you think my turbos are toast?
FBO 335is
Default 04-27-2019, 06:39 PM
70k id imagine they’re okay.
Inspect what you can physically & if you can’t perform a boost leak / pressure test yourself, I’d find someone who can.
Car: 2012 335is
Default 08-16-2019, 12:29 AM
boost leak found and fixed hopefully we can continue with making a custom map 6? here's a log on map 5 e60 and e85 bef
FBO 335is
Default 08-16-2019, 12:42 PM
Doesn't look bad, however LPFP is teetering on the edge up top.
Do you have an upgraded LPFP?
Car: 2012 335is
Default 08-16-2019, 02:37 PM
yes, I have a fuel it stage 2 pump
FBO 335is
Default 08-17-2019, 07:28 PM
Check for kinks - psi should be higher - could also be failing EPK
Car: 2012 335is
Default 08-18-2019, 01:48 AM
I'm going to light my car on fire (kidding). Checking for kinks would be for the fuel lines connecting to the lpfp? Can a EPK fail on a 2012 n54?
Will resolve and come back to this thread or sell and get a M3
FBO 335is
Default 08-19-2019, 11:46 AM
I'd pull the bucket itself & give everything a once-over
EKP can fail regardless of year
