bleedsblue0023's Avatar
bleedsblue0023 bleedsblue0023 is offline
Default N55 PWG 2BE9 Code - Car Stalled, LPFP issue? - 04-10-2019, 07:19 PM
So I had my car stall in limp mode for the 2nd time with a fuel pressure code.
It has done this with straight 93 - 8% e85 pump gas, and today at E38.
My mods are in my signature, although the TBI is not working right now, I have a stage 2 pump and upsized feed line. (issue with the nitrous trigger).
I have been running up to E70 with the TBI functional, and E55 with it off and had no issues until now.
Under load I have high fuel pressure readings of 15 or so at 12 psi.
On a short pull I have seen trims spike to 40 on pump 93 at 8psi.
My gut is saying my stage 2 LPFP is failing. Thoughts?
Houston, TX
Jet Black 2011 335i Sport 6MT:
Mods:
BMS Intake, JB4 Iso, BMS E85 BEF, CPe Chargepipe, ETS 5", Megan Racing turbo outlet, BMS OCC, SS Brake Lines, BMS CDV, MFactory LSD + mounts, 335is clutch, MFactory SMFW, 650i finned diff cover, Pure Inlet, Fuel-it Stg2 LPFP + Plat TBI, E46 Trans mounts, Turner Pedals, Mishimoto wheel lugs, Turner 10mm spacers, Msport Interior, M3 armrest, M3 Control arms, EvoRaceWerks F30 TIC pipe
Default 04-22-2019, 08:36 PM
An update for anyone that had the same symptoms. It appears it was my hpfp. I had a few more bad stumbles and had to nurse the car for a few days while the pump shipped, but it was not a terrible installation. Just an expensive bit after i just fixed my water pump, thermostat and a diff bolt. I ran a few logs tonight and will need to relearn on e85 as my trims are crashing low, but it is hitting and holding full throttle now. 75k fyi.
Houston, TX
Mods:
Default 04-23-2019, 12:36 AM
Default 04-25-2019, 04:21 PM
So I think my new fuel pump just failed. I would appreciate a log review. I have an ok pull, one that looks like a weird crash, and finally a log with the failure where the car cut off. It also does again after I pulled the battery while sitting in traffic not moving.
If anyone else has an idea like a bad CANBUS connection or a hole in the back end flash i would appreciate a review.
Houston, TX
Mods:
Default 04-25-2019, 09:40 PM
The first log I see the hpfp tank.
The 2nd/3rd log- looks normal.
Where’d you purchase the pump from?
Default 04-25-2019, 10:01 PM
FCP Euro
Houston, TX
Mods:
Default 04-25-2019, 10:14 PM
FCP Euro
Log cold start tomorrow if you can / post.
Was the pump new or remanned?
Default 04-26-2019, 09:05 AM
Cold Start csv attached.
Houston, TX
Mods:
Default 04-26-2019, 12:19 PM
Yes the pump was reman. I just picked up a brand new one from the dealer to install tonight.
Houston, TX
Mods:
Default 04-26-2019, 11:34 PM
Should do the trick- return pump to fcp asap
Default 04-27-2019, 10:13 AM
Yeah. Should get a full refund. I'm good at replacing these now lol.
Houston, TX
Mods:
