joebarteam74 joebarteam74 is offline
Car: M140i
Default custom Map TTE580 + map6 JB4 - 09-11-2021, 10:58 PM
Hello,
I have a turbo Hybrid the TTE580 and a Map customize by pureboost in germany.
I am not far from 580 ch but sometimes on the gear ratio of 5 and 6 em I have overboost I exceed 30psi.
my question:
can you use JB4 with the MAP 6 to regulate the boost to 28 psi for example?
Are there any parameters to indicate and how to use it when you have a custom map on MHD.
thank you for your support
joel
Car: M140i
Default MHD custom tune + JB4 MAP 6 control boost - 09-19-2021, 01:43 AM
Hello
so i'm surprised no one answers the question?
I will carry out tests to confirm the settings soon and will send you LOGs.
now if someone is able to advise me on adjustments in order to maintain a correct boost as a reminder, my pump drops in pressure from 30 psi + the overboost cutoff which must be operated by the bosh computer ..
and I still wonder what is fuel bias and duty bias in the parameters of map 6?
