Car: CTS-V
01-23-2022, 06:02 PM
Is an Auto tuning mode and no-lift shift going to be a possibility for the G80?
If so any ETA?
Car: G80 M3
02-02-2022, 02:11 PM
guys, in the v8 alpha firmware the maps were changed so that map 3 is now also an additive boost map (+6psi), but the map descriptions in-app were not updated. Can you please clarify what are the target settings of the rest of the maps now in v8 ?
02-06-2022, 09:13 AM
As most people are not using alpha firmware we can't update the global map descriptions, until that version becomes production firmware. There were also minor changes to map1 and map2. You can always log the map and look at your target parameter if interested in the details.
Car: CTS-V
02-09-2022, 10:40 AM
If so any ETA?
Bumping this as inquiring minds want to know.
02-11-2022, 08:28 AM
We have not looked in to no lift shift, but have various autotuning maps including E85 maps that utilize the Fuel-IT flex fuel sensor in testing/development.
Car: CTS-V
02-21-2022, 09:40 PM
Any need for the wired connection or can you do everything via Bluetooth including firmware updates?
Car: Evo VIII
02-22-2022, 01:23 PM
As long as you have the JB4 Bluetooth Connect Kit, you will not need any direct connections and everything can be done via Bluetooth!
Car: M235i
03-06-2022, 12:43 PM
Hey gus i just purchased a jb4 for my x4m comp looking forward to installing it when it arrives. Although im looking forward to the power increase mostly i was curious if its possible to have a neutered map to increase gas mileage for daily driving not sure of if that exists, also i see theres a few different firmwares available for the s58 do you recommend running the latest one which seems to be V8?
03-06-2022, 08:14 PM
Always run the latest firmware but if you just ordered it...you likely don't need to update it.
To "neuter it" you could run map 8.
Car: M235i
03-06-2022, 09:38 PM
Hey Steve thanks for the reply i wasnt sure if map 8 was still low boost i see on the original post the list says its as off V5 and it seems to be at V8 now wasnt sure whats changed.
Car: E92 335is
03-22-2022, 08:06 AM
Does the JB4 is deleting fault codes for ******* *********?
Car: 2020 c43
04-07-2022, 06:21 AM
Anybody have any HP figures on race gas?
04-10-2022, 09:11 AM
No BMW only allows faults to be deleted while vehicle is in diagnostic mode.
04-10-2022, 09:12 AM
Originally Posted by Evanb235
Got to installing the jb4 today did a few logs let me know if this is the wrong forum to post these. I will try and get better ones started on map 2 felt like boost was spiking and maybe throttle closures? map 1 feels better
You'd need to attach the CSV logs here directly.
Car: g80 M3cx
04-14-2022, 07:30 AM
hi guys, I did some test of the map 5 on V7_T4 with an E33 mixture, I am not expert in log reading, but from what I know it seems not so bad apart from the boost which normally would like to be a +-1psi of the target but I am 2+psi above and I can touch 31-32 psi before falling back map0 and I put safety boost a 29 , it may be normal, that's why I ask you! in my log I have 2 runs, a log run in 4th and a quarter mile! please let me know if this is ok or what i need to improve!
thank you in advance!!
04-15-2022, 07:34 PM
Log is pretty good considering. I'd raise boost safety to 32psi to get it out of the way, update to the alpha firmware, and relog.
Car: g80 M3cx
04-20-2022, 06:13 PM
thank you Terry ,safety boost set a 32, here log of quater miles and 4th run map5 v8 alpha firmware also add 4th run map 4 all e35 mix ! log look pretty similar but the car switch to somekind of rpm protection mode (redline drop at +-4000rpm) right after quater mile run  nothing else abnormal, restart the car and everything ok! have you seen this before?
thx again!
Car: 21 Supra 3.0 / 18 RS3
04-21-2022, 06:49 PM
I upgraded from a M240i to a M4 Comp Xdrive, and just ordered a JB4 for the S58. Can I use the same connect kit from the B58 version of the JB4?? Thanks!
04-22-2022, 06:43 PM
Yes!
Car: 2008 335xi coupe
05-06-2022, 08:37 PM
Yes!
Terry. Any chance you might have a look at this log? Bandimere speedway tonight. Map 3 with 94 octane. 8400 DA.
Curious if I’m too aggressive for Denver altitude?
This log contains both a map 3 pull on the track, and then a map 1 pull later in the log.
https://***********/u/forza1976/band...1&zoom=649-852
Thread Tools |
Display Modes |
