Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2022 X3 M40i
Default She's not thrilled with Map 2 - 11-07-2021, 03:22 PM
0-60 was nearly .3 slower than Map 1 on the same road (3.58 vs 3.87 on the Dragy), though in fairness, this tank has less ethanol in it.
Mike Levy
2022 Black Sapphire X3 M40i
Boosted_8 Boosted_8 is offline
Car: M550i
Default 11-08-2021, 09:54 AM
Map 2 hasn't been developed for the 523hp engines. Its waaaay too much boost. +6psi is asking for trouble IMO.
Car: M550i
Default 11-08-2021, 10:01 AM
PS: To get a clean log with more data sampling. Head to the highway at night and do a 4th gear pull from 2500/3000rpm to redline in manual. I expect you will be hitting over 22psi in 4th gear in Map 2. That's M5 comp boost level...
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 11-08-2021, 12:16 PM
Yeah, I just tried it again and she did 3.91. This Map isn’t working or this gas isn’t.
Unfortunately there are no highways around me. I’m 25 miles from the nearest one, and that one has heavy traffic all the time. I gotta take it tomorrow, so if I get an opening I’ll work on getting a longer, better, log.
Mike Levy
Car: M550i
Default 11-09-2021, 05:08 AM
A longer duration log will help with the conclusion, however I suspect without a d0wnp1pe you will struggle to hit targets lower down and up high the boost will come at the expense of timing. I'm reaching 22 degrees at 6000 rpm on pump fuel right now. 23+ with a little extra octane.
zse8h zse8h is offline
Car: M5501
Default Will Ca**esl*ss Dow**Pips - 05-08-2022, 10:19 AM
Fix the problem and worries of running map2 and having +6 psi of boost? I mean high flow C*tt**Ed!
2021 M550i
Bernina Grey Amber Effect
BMS Elite Intakes
GPower Axel Back High Flow Sport Silencer
Active Autowerke High Flow DwnPips
HardRace rear sway bar and Dinan lowering springs
Barracuda Racing Wheels (Inferno)
JB4 Map 1
Retired:
2009 335xi
Completely Moded out
Beat corvettes - they were pissed
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 05-08-2022, 12:18 PM
I've done nothing. Just demodded. My new X3 is scheduled to be out of production on Friday, so I'm not long for the N63 world.
Hoping the B58 is more mod friendly. The part availability is sure better.
Mike Levy
Car: M5501
Default B58 - 05-08-2022, 12:30 PM
Mike, i think it is. I found myself watching a YouTube video of a guy introducing a 3 stage process to get that engine to 600+ HP. All parts seem readily available too. Sad to see you leave the n63 community but I get it. I can't believe I have to ship my ECU to Russia in order to flash it. So painful.
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Tomholland Tomholland is offline
Car: Bmw m550i
Default 05-11-2022, 08:38 PM
Well that sucks you have been helpful. For what it's worth, I sent a log of map 2 to terry and he said it looked fine. Wonder if ********* and e85 make a difference.
Antec800 Antec800 is offline
Car: 340ix
Default 05-12-2022, 02:15 PM
On map 2 you canít run more then 2.5 gallons of e85 without running to lean, and I also have a ******* ********, my custom settings for map 6 is 5 psi Through the whole rpm range and it runs faster 60-130 then map 2
