Swerve Swerve is offline
Default bizarre throttle body adaptation codes surging idle plz help - 03-30-2021, 06:40 PM
Happened all of a sudden when I switched my anti lag wire into the correct slot on large black sub connector. When I started it up idle was surging and the gas pedal had no effect on the revs. See pics for codes. Could my throttle body have just took a sh1t randomly?
Default 03-30-2021, 06:52 PM
yup i think my throttle body legit just sh!t its pants right before my very eyes... see this video thats what my car does. N54 surging idle. SOLVED! - YouTube
Default 03-30-2021, 07:13 PM
Im just going to talk to myself. Yes your throttle body probably took a sh!t replace it.
OK thanks a lot!
Lynxs1981 Lynxs1981 is offline
Car: 2008 335
Default 03-31-2021, 07:37 AM
Tried removing the JB4? Having the same issues; car runs great with JB4 removed. Seems to be an issue with the BSD.
Default 03-31-2021, 12:27 PM
whats the BSD? How is this resolved?
Default 03-31-2021, 12:42 PM
I took the jb4 out and its still doing the same thing... Let me know how you get that issue resolved.
Default 03-31-2021, 01:29 PM
I then flashed back to stock and the car is running normal again... Then I installed just the jb4 and its back to the surging idle. Anyone from burger have anything to say about this?
Car: 2008 335
Default 03-31-2021, 01:59 PM
That’s the same boat I am in; haven’t found a solution yet. Did you check the black 44 pin ecu connector? The throttle signals run through it.
Default 03-31-2021, 02:14 PM
I'll have a look. This happened as I was messing with stuff trying to get antilag wired in correctly. Check out the post I made ATTN BURGER MOTORSPORTS.
Milehighbmw Milehighbmw is offline
Car: 07 335xi
Default 03-31-2021, 08:31 PM
Have you done a throttle reset?
Push start button without the brake (acc on)
Push gas pedal to the floor
Keep it down for 30 seconds
Turn car off without releasing the throttle
Release throttle
Wait 2 minutes
Start car
Google e90 throttle reset. There's videos
Car: 07 335xi
Default 03-31-2021, 08:32 PM
From that list of codes my guess is your battery is going bad.
