BenjiB707 BenjiB707 is offline
Default 335i Crank seal DIY: NEED TOOL!! - 10-17-2016, 02:02 AM
Any member on here do the seal replacement and have the tool? If so, who can rent the tool out to me and or show me a cheap alternative to buying it (250$).. Or nicely let me rent it thanks in advance !!
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 10-17-2016, 07:45 AM
try
http://www.bimmertoolrental.com/
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: 2010 535i
Default 10-17-2016, 08:13 AM
I think @ucsbwsr drilled a tiny hole in the edge of his old one, screwed in a small screw part way, then pryed it out by the screw. Not sure how he put the new one in, but he has definitely done it without the tool.
Default 10-17-2016, 10:42 AM
Very short tap screw. Screw into old seal then use pliers to pull. Lube new seal and use a big enough socket or cylinder to hammer in at once to go in evenly.
Default 10-17-2016, 11:15 AM
Have you done this before? Or know someone that successfully done it or thats an idea?? Im scared
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 10-17-2016, 12:33 PM
Are you talking about the front seal around the crank hub or the rear main seal?
For the rear main seal I drilled a small hole, inserted a screw, and pulled it out with a hammer. I used a similarly destructive method to remove the large sealing cap on the front side of the engine. Never removed the front crank hub seal.
Evan
N54 Powered M5 Wagon:
Default 10-18-2016, 04:51 PM
Evan
Do you think it would be same with the front seal?? Im going to try it
longnvu longnvu is offline
Car: 535i
Default 10-21-2016, 02:04 AM
Im selling a new bottle of sealant and primer if you need them.
Nexic Nexic is offline
Car: '10 335i
Default 10-22-2016, 06:24 AM
I recently installed a new rear main seal. Went in dry, per instructions. The primer is no longer used on the new seals. You can get a seal puller from your local auto parts store and remove it. I also sealed it with grey rtv sealant. I have not had any issues and it is still dry as a bone.
Car: 535i
Default 10-24-2016, 07:22 PM
the front requires primer and sealer
victor247 victor247 is offline
Car: 2008 335i Vert
Default 01-28-2017, 11:50 PM
I'm about to do the front main seal myself. BenjiB707 How did you end up doing it?
2008 335i E93 Single turbo
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 01-29-2017, 08:33 PM
Honestly as important of a job as this is I would just buy the tool if you can't rent it from someone.
This is the best deal I could find
https://www.amazon.com/Front-Cranksh.../dp/B01BCQSUP2
2008 335i Sport Jb4, MHD BEF, Alpina flash, Uncatted pipes, PE Mod, Injen Intake, v710's , Vogtland Springs
Car: 2008 335i Vert
Default 01-29-2017, 09:02 PM
I guess that's what I'll end up doing and then rent it out to people myself.
5Dirty5's Avatar
5Dirty5 5Dirty5 is offline
Car: 2008 BMW 535I
Default 01-30-2018, 11:33 AM
Did you end up buying the tool? I'm about to do my front seal on my 2008 535I
Car: 2008 335i Vert
Default 01-30-2018, 12:13 PM
Yes I got it.
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 01-30-2018, 01:09 PM
Originally Posted by victor247
Yes I got it.
YES!!! would you rent/loan it out to me? Possibly?
I'm Located in California.
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 01-30-2018, 04:30 PM
I have the fuel injector removal and installer tool. We should have a spot for other members to share tools!!
Car: 2008 335i Vert
Default 02-05-2018, 09:53 PM
For the folks sending me messages for the tool. I just loaned it to 5Dirty5. Waiting for it to come back.
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 02-06-2018, 02:24 PM
Just got mine R/R damn what a SOB....canít imagine trying to do this without the tool!! Thank you again Victor!! You are the man!!
Loyola0917 Loyola0917 is offline
Car: BMW 335i 07 sedan
Default 02-11-2018, 10:09 PM
Victor would I be able rent your tool?! Iím located in Los Angeles?
My first time writing on this forum so hopefully reaches you
Moos209 Moos209 is offline
Car: 2008 BMW 528i
Default BMW front crank seal tool - 09-21-2018, 02:31 PM
Hey victor, just sent you a PM. Would love to rent out that tool from you if possible. I live in Stockton, Ca. Any help appreciated. thanks man
Car: 2008 BMW 528i
Default BMW front crank seal tool - 09-25-2018, 04:58 PM
Attempting to remove / install crank seal now. Leaking oil filter housing causes drive belt to get destroyed. Pieces of drive belt were lodged behind the harmonic balancer which ate up the seal. Awaiting new parts and installation tool now. If anyone has questions on how this procedure is done id be happy to try and help.
[IMG][/IMG] [IMG][/IMG]
AnilKram AnilKram is offline
Car: 09 135i
Default 09-25-2018, 07:54 PM
Need to rent the tool also if anyone is willing?
09 135I MT jb4 g5/MHD Trebila backend Frankenturbo F21 FBO, PI, stage 3 lpfp, full E85, Quaife LSD
Car: 2008 BMW 528i
Default 09-26-2018, 08:51 AM
Where are you located?
Car: 09 135i
Default 09-26-2018, 11:58 AM
Tucson, AZ
