(#401)
Default 02-13-2022, 05:58 PM
Latest firmware has all previous changes. You can email logs to yourself and attach to posts that way.
08fordgt 08fordgt is offline
Car: 18 Alfa Romeo Giulia Ti Sport
Default 02-13-2022, 09:36 PM
All of these were after i checked the torque on my full exhaust system, and did a complete check of my engine bay including moving my jb4 to a different spot and wrapping it just in case it was causing false knock.
Default 02-13-2022, 09:38 PM
another pull. I guess the other two log files are too large for me to post.
Default 02-13-2022, 09:56 PM
Logs seem fine to me. What's the fuel/mods?
Default 02-14-2022, 05:02 AM
93 octane. Eurocompulsion V2 intake, supersprint sport exhaust, and a turbosmart diverter valve. So IGN 2-5 are good even though they're showing positive or will they go negative if they were knock? I'm still trying to piece together how to properly interpret your systems measurements. Thank you.
Default 02-14-2022, 09:51 AM
There are always going to be some timing corrections by nature of the dynamic timing system which continually rides the knock threshold for increased fuel efficiency. Even at WOT. What we'd be looking for is excessive corrections indicating a plausible timing curve for the octane and boost profile is not possible. Then you know you need to lower boost and/or increase octane.
Default 02-14-2022, 11:54 AM
Awesome. Thank you for the explanation.
Tekgnome Tekgnome is offline
Car: Alfa Romeo Giulia Ti Sport Q4
Default 02-22-2022, 09:36 AM
Good morning Terry,
I'm reaching out as I've been developing a hybrid turbo with NM Turbo and its finally finalized. This means there are now two solid options for people to buy hybrid turbo's for our platform. (NM Turbo, and GotTuned)
I was wondering if it was possible to work with you to develop a user selectable Map to make it easier for others to run a JB4 with a hybrid unit. (bhvrdr) has been running a JB4 with his hybrid on a custom map with great success.
On a second note, I have also been wondering if it would be possible that the JB4 in the future will add a third signal intercept to allow us to adjust fuel pressure, there's a system(who's name wont be mentioned here) that can do this already, and it would be nice it we could as well. (as far as I can tell this isn't really necessary and is more of a nice to have than a need)
Thank you for your time.
Default 02-22-2022, 10:16 AM
Sure send in a log and we can evaluate it. The plan for these is for o2 sensor control to attenuate trims and air/fuel ratios. Fuel pressure only gives you fuel trims which isn't a factor on the platform.
Default 02-22-2022, 11:00 AM
02 sensor control would be fantastic!
I'll need probably a couple of weeks to get time to install my Hybrid and ******* ********. I have MES and can also provide any logging necessary with the JB4 as well.
Not sure why it censored my ***? I guess emissions talk isnt allowed here, I cant seem to find the forum rules.
Default 02-22-2022, 02:30 PM
Yes can't discuss bypassing emissions equipment as it's illegal in the USA. But no problem on tuning.
ddaversa ddaversa is offline
Car: KIA Stinger + Alfa Romeo Stelvio
Default Updated info? - 06-09-2022, 10:42 AM
Hey everyone / Terry,
new to this particular forum because I just got a Stelvio for my wife, but I've been at it with my Stinger for 2 years now, so I know how the JB4 works...
I read each and every post in this forum so far, and I'm left wondering where does the JB4 stand for the Alfa Romeo 2.0L ? I know the 1st post is always kept up to date, but I also noticed the graph seems to say only about 25 hp gain, though the page says 40 whp (55 crank), so I'm confused. I can't seem to find fuel requirements for the maps.
I'm going to buy [today] the jb4 and the performance intake. Going to run it on 91 octane, but I could also get 94 (w/ 10% ethanol). Which map should I go with? Does anyone recommend any other performance mod?
Kind of exciting if I can bump this to a theoretical ~340HP, pretty impressive power in the end!
TY!
Default 06-21-2022, 08:12 AM
Most likely map1 is the best fit but log it and we can always review.
