Car: 2021 M550
05-01-2022, 11:29 AM
Sheesh so my bolt ons would only net me only 10-15 hp vs a stock car running JB4
Anti-Social
Car: 2022 X3 M40i
05-01-2022, 01:17 PM
Originally Posted by cwhit122
Sheesh so my bolt ons would only net me only 10-15 hp vs a stock car running JB4 ��
Thats peak. Some rpms will be higher, some will be lower. BMW didn't leave much on the table with the N63B. The intake and exhaust tracts are pretty free flowing.
Mike Levy
2022 Black Sapphire X3 M40i
Car: 2021 M550
05-01-2022, 01:24 PM
Gotcha, so to truly see major power improvements would be pure turbos and more fuel options? All I ever seen was getting *** less ********* would net so much HP from the restrictive OEM ones. Maybe that was from a flashed car or combo of both with a jb4 integration. As always thanks for the good replies.
Car: Bmw m550i
05-01-2022, 08:59 PM
Intakes don’t help much but a ******* down pipe did. It dropped my 0-60 down .2. And that was consistent through multiple runs.
Car: 2021 M550
05-02-2022, 05:34 AM
Yeah that’s what I thought for DP lol. CAI only for sound anything else is a bonus
Car: M550i
05-06-2022, 02:22 PM
Originally Posted by Antec800
Noticed the same issues doing runs tonight on map 2? Any solution?
My current theory is gearbox torque limiters. Xhp support for the current 8speed ZF boxes is due in the next couple of months. My plan is to settle that asap
Car: M550i
05-06-2022, 02:25 PM
Originally Posted by zse8h
BMW finally got around to upgrading my software to 07/2021.20 from 03/2021.40. I noticed immediately how firm the car's stance feels while driving and how smooth the car drove and shifted gears. Testing is with no JB4 as I had to take that off for a visit. But the car feels so much easier to control, and the power on stock felt beefy compared to the previous software. Dare I say it felt like a different car??? Anyhow, this is just my first impression after driving it a few hundred miles on no tune and just a software upgrade.
Fast forward to today, 19 Jul 21. I drove the car a good bit before work on the way to grab some coffee as I wanted to test the car's balance with a new rear sway bar. I want to say this investment is well worth it. It took 1 hour to install, using a lift and making sure my 4-year-old didn't run into the street.
Altogether, it was four bolts and two nuts. The bar itself was tricky to remove once unbolted. The driver-side control arm needed raised an inch to slide the bar out.
I hope this is informative.
Zach
I went for the OEM F90 bars front and rear in the end. I had them fitted with front camber arms and a geo setup. The shop said they went right on with the M5's brackets and a combo of the drop links from both cars.
Car: Bmw m550i
05-06-2022, 03:16 PM
Have you tried turning traction control completely off and not use launch control?
Car: M550i
05-07-2022, 01:12 AM
Yes. That approach is only avoiding the problem because you are not building any boost or using the aggressive shift pattern.
Car: M5501
05-08-2022, 06:24 AM
This is wonderful news. Do you have aftermarket springs for a 3/4 inch drop? Maybe this will be my next project. How much did the parts cost you?
Another topic, I'm running 102 octane, axel back exhaust, Ca**d Pipes, and JB4 map 2. Today I went from map 1 to 2 and holys...t. i think I need draggy! Don't you run a similar setup? How do your logs look between map1 and 2, with and without pipes? I think Mike' hates map 2 but he doesn't run pipes or 102 octane.
Thoughts??
2021 M550i
Bernina Grey Amber Effect
BMS Elite Intakes
GPower Axel Back High Flow Sport Silencer
Active Autowerke High Flow DwnPips
HardRace rear sway bar and Dinan lowering springs
Barracuda Racing Wheels (Inferno)
JB4 Map 1
Retired:
2009 335xi
Completely Moded out
Beat corvettes - they were pissed
Car: M550i
05-08-2022, 12:35 PM
I genuinely do need the ground clearance and compliance of the M550i suspension, shorter higher rate springs are a no go. With continental sportcontact 7 tyres and lighter forged wheels in place of run flats and the cast iron 668s, the ride is so so good.
Regarding map 2. It never ran right for me. It asks for +6lbs everywhere and even with 101ron (94+2 points of boostaine ) the boost came at the expense of timing and the car was slower. I have the stock primary cats still in, everything else in the OEM exhaust is out of the way.
Car: M5501
Point is -
06-22-2022, 08:14 AM
Map 2 isn't ready not even for 102 octane we need a flash tune. Truth be told the piggy backs are not ready for this car when we want to produce real power.
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Car: 340ix
06-22-2022, 03:31 PM
I ran the fastest 60-130 times on custom map 6 settings all 5.5, what’s your newest map 6 boost settings
Car: X5 M50i
06-23-2022, 08:19 AM
Originally Posted by Terry BMS
The fuel limit we're fighting on the JB4 end is with fuel trims. So flashing the ECU would certainly help. As would adding external fuel like WMI or CPI. I don't know where the fuel pressure limit is yet but I'm sure that's well above 600whp.
On the required connectors yes we have them, email me your address and we can send a pair out. Payam is going to make a video on how to attach them to the JB4 harness.
Terry, does this log look a little sketchy? (26lbs was not intended and has not been ran since) Trying to determine safe max boost targets for this platform on an M50i. Currently running a map 6 with 7.5 additive from 4,5 to 5,5K, tapering down to 6 by 6k.
Car: M550i
06-23-2022, 08:26 AM
What is your objective? Max boost doesn't equal max performance.
Car: 340ix
06-23-2022, 05:06 PM
I get **** timing above 6lbs on e25-e30 I can’t imagine what 7psi extra would look like, car probably is just as fast as stock unless you’re on meth or race fuel
Car: M550i
06-28-2022, 10:54 AM
It looks a bit like the sweet spots in terms of boost by octane on the Tu3 are starting to be evidenced by the community e.g. +3lbs for 91, +4lbs for 93 +5lbs for 95, +6lbs for 97+ after this the stock turbos just seem to be blowing hot air.
Car: 340ix
06-28-2022, 01:49 PM
You’re not running 7.5 additive anywhere the highest I see on your logs are 6 at 4.5-5k tapering down to 4 then 2 then 0,0, and I think the highest additive is 7.2 before it switches to absolute anyways
Car: M550i
06-29-2022, 12:18 PM
Was able to get a M550 on the dyno yesterday for a little EWG testing. The good news is we sorted out the connectors. It's pretty easy to "convert" the EWG connection by repinning on a replacement connector.
The bad news, we didn't see any real performance gains with EWG on the platform. Fueling was the limiting factor so unless you're running WMI there isn't going to be much EWG benefit.
Baseline was done on 91 octane, and then map2 without EWG, on 91 and also E20+91 (around 93 octane), for comparison.
What does a stock M5 running the same fuel make on your Dyno?
Car: X5 M50i
06-29-2022, 02:41 PM
2 things on this:
1. Showing 26lbs and stating I'm no longer running that. The logs are combined and I switched to an absolute mid way through that obviously needs some PID power added to it
2. Stating what I'm currently running in terms of 7.5 requested over
Car: X5 M50i
06-29-2022, 02:43 PM
I would disagree considering I'm running smooth a 18.6lbs at 3,5k ramping up to 29.4lbs by 5,1k while on e30...
Car: 340ix
06-29-2022, 02:49 PM
Do you have ewg wires I thought pid isn’t affected without, and what do you mean by more pid power
Car: X5 M50i
07-05-2022, 10:47 AM
Sounds like Map 2 is not a good choice at this point. Looks like Map 1 for a novice like me.
Wondering if an E30 mix of 93 oct. and E85 would yield any additional power on Map 1. Has anyone tried that?
Car: 340ix
07-05-2022, 03:57 PM
Not on map 1, and not required on map 2, but even on map 2 with 93 octane timing isn’t good without e85/octane booster
Car: M550i
07-06-2022, 01:58 AM
I wish you luck in whatever it is you are trying to achieve.
