Car: 2016 vw jetta s 1.4 tsi
EA211 1.4tsi checking in -
04-06-2019, 09:01 PM
Just want to say it been a week or so since I've had my jb4 installed and I absolutely love it! Hoping to figure out something to do for the turbo and feed this car more boost. So far at 19psi and it feels amazing, hard to drive in the rain but i love every minute of it. Thank you guys so much for making this happen!
04-08-2019, 11:05 AM
Awesome!! It really wakes up the car in the low end.
04-08-2019, 02:12 PM
I hope to see more development for the 1.4, its a great platform. You guys made me really enjoy this car and I've recommended the jb4 to everone I know
Moderator
04-09-2019, 08:51 AM
Happy you enjoying it. We should have boost per gear working soon to dial in some traction in first gear.
2021 VW Golf 8 R
04-09-2019, 09:55 AM
I think the spinning makes it more enjoyable!
05-04-2019, 06:41 PM
just installed and silicon pipe with an external blow off valve. tweaked map 6 just a hair and got it up to 19 psi. also just replaced the turbo in my car with one with lower mileage just to be safe, (car has 77k on it, new turbo only 45k) i have some logs of what ive played with and the car feels good, cant figure out this whistling noise i have coming from the engine when i build boost. all my tubes are tight and i removed the tube system that diverts boost air pressure back into the inlet side of the turbo. the turbo it self is good, zero shaft play, no damage to the fins and is clean through and through. have you guys seen any failed parts on the 1.4 during testing?
Moderator
05-05-2019, 09:06 AM
We went through two turbos at boost slightly higher than that but also at high altitude (5600ft). On the last one we got a whine from the turbo at idle worse when colder but no noise once boosting. I reckon at 19psi I wouldn't go higher on stock turbo.
2021 VW Golf 8 R
05-05-2019, 10:04 AM
Mine only makes noise under load. Idle is fine, all my logs look good, a/f stays around 12.1, spark advances 3* at full boost, no knock or ping under full boost so I know the fuel and ignition is on point. Just has a loud whistle like it's an air leak, but doesn't show any sign of leaning out. I'm at sea level down here on the gulf coast and all the warm humid air hasn't seemed to hurt anything. Just can't pin point the source of the noise.
Also to add I'm running 93
Car: F30 335 in USA & MK7 TSI in COL
06-02-2019, 05:45 PM
I’ll be hooking up JB4 to my ROW Golf EA211 ... 6MT. I only have 91 available to me so I’ll be sticking to Map 1 for a while until I get more familiar with the JB4 in general.
Because you have been using it for a while now, do you mind sharing anything that you feel a new owner “must know” based on your experience?
Thanks a bunch !
06-02-2019, 07:22 PM
Thanks a bunch !
You will absolutely love it! Map 2 is fun as well and you should be able to run either 91 or 93 on both. George jas set me up with a map 6 setup and I've loved it so far, he's the man to ask for custom tunes. Advice i have is before hooking it up if you've used 87 before this unit, run all of it out and fill with 91 and run it until the 87 is all out to prevent any possible issue. Having killed a turbo once take the advice from George here and have fun with what you have. I personally love the laptop software over the blue tooth kit but to each their own.
06-02-2019, 07:28 PM
Wow, thank you so much for the invaluable insight. I agree that George is fantastic. I have not worked with him on tunes but I did annoy him for nearly six months on the status of the EA211 release.
I truly appreciate the feedback. I am away from the car so in about a week I’ll check in with some updates on Map 1 and allow myself to tinker a bit. Unfortunately I did not opt for the data cable. I’ll keep an open mind about the Bluetooth dongle.
All the best,
Carlos
06-07-2019, 11:32 AM
Kind of bummed out... yesterday I installed JB4 and followed instructions precisely. Car started right up but the Bluetooth connect kit would not connect to APP. It was reading the Bluetooth dongle but no connection. I contacted Bluetooth support, I was told issue fixed.
This morning I go to start the car and after a long crank it comes alive misfiring. Now the APP can’t even see the Bluetooth APP.
Disconnect battery, uninstall JB4 and car fires right up without errors. Frustrating to say the least.
Car: VW golf Mk7 1.4 tsi
06-26-2019, 10:37 PM
It's your car a Golf? If so, I might know what's up as I had a similar issue and found a workaround.
06-26-2019, 10:50 PM
Hey there, yes, Golf with a 6 Speed.
I’m told an issue with the JB4 not turning on fast enough ? Any insight would be amazing before I ship this back to the US.
Thank You!!
06-26-2019, 11:05 PM
Thank You!!
Yes, that is the issue. Your unit doesn't get power before the ECU does its self checks and detects an open loop on the sensors that the JB4 attaches to. What I did to remedy this while a new board design was being worked on was to have the usb data cable always attached to a phone or tablet before turning the engine on.
In my case it helped that my headunit is basically an android tablet so I had the usb data cable connected directly to it, that stereo has a battery so the usb port that the jb4 data cable is connected to always has power running to it so it doesn't matter if the car is turned off, once the checks start when you open the ignition circuit your jb4 is already "awake".
I just re-read your first post and it seems that you are using a bluetooth connection so that might prevent you from using my workaround, unless you can source a data cable locally.
To me that works fine as I got a little impatient about the board update but I can see that it's not ideal.
06-26-2019, 11:13 PM
Clever! Makes a lot of sense. Unfortunately for me finding a data cable locally is a no go. As such, I guess I’ll have to wait for the fix to be released. George has been responsive.
Do you also have a 6 Speed ? Where are you located ? I was told it was a known issue in Mexico. I’m in Colombia. Are you happy running Stage 1?
Thank you again for being kind and sharing your fix.
06-26-2019, 11:22 PM
Yes, it's a golf and I'm in Mexico. I think I was the first one to encounter that issue. (bug bounty pls)
The upgrade in torque on the low end is very noticeable and stage 1 is fine for most driving conditions. I ran a trackday recently and was left wanting a bit more but I didn't want to risk the turbo by pushing it with the Map2.
Since then I installed a front mount intercooler and got a hybrid turbo. it spools faster even considering that the piping for the intercooler adds some lag so I might start playing with map6, or get a custom tune but for daily driving the map1 will leave you very satisfied.
06-27-2019, 10:54 AM
I say a bounty is very well deserved! Sounds like you got quite a few upgrades to make the ride a little more zippy. Honestly, I’m happy with the car the way it is but I do need just a tad more and that’s mostly because I’m coming from a Stg. 2 335 back home in the United States. For Colombian roads I’m sure the 1.4 with just a bit more spice will be more than enough.
I’ll PM you so we don’t hijack the thread anymore !
Thanks again.
Moderator
06-27-2019, 03:30 PM
Drop me a email. george@burgertuning.com We have the fix ready and it seems same harness can be used. I can ship the board over to you and we can see if it sorts it.
2021 VW Golf 8 R
