After getting bored with my daily driver E70 X5, I sold it and started my search for a new project. As I continue to grow my YouTube channel, I wanted something that I could daily drive and modify. Since I know my way around an N54, I found myself looking for an E90 335i. This would give me 4 doors and a plethora of options to pick from. My only stipulations were that it had to be automatic, cheap, and not a pile of crap.
My search across the Midwest uncovered a lot of overpriced junk. As a member of E90Post, I stumbled across a listing that hadn't been getting much interest over the course of 3 months. I noticed the price was more than fair after a few price drops and the car seemed to be a great value. I contacted the seller and asked a few questions. Everything seemed legit so I had him bring it in for a PPI at a local BMW indy shop.
Next thing I knew, I was scheduling transportation from Texas to Wisconsin.
I took delivery of the car sight unseen and am very happy with the car. The transaction went smoothly, the seller was great to work with and I get to enjoy a rust-free chassis!
It's a 2009 BMW 335i (N54) with 140k miles. Face-lift sedan with sport package, premium package, heated seats and comfort access. Tons of maintenance records and tastefully modified with a Dinan carbon fiber cold air intake, JB4 tuner and window tint.
I have lots of plans for it because I'd like to make this an exciting build with modifications and maintenance. It'll start off like most N54s, but I'm really gonna turn things up later on this year. I'd like this to be a budget-built stock turbo drag car. I still have my 750whp 135i (see here), but this should be the polar opposite being an automatic, twin turbo sedan instead of a manual, single turbo coupe.
Since I've had such good results with this method, I created a DIY video that shows the steps I take and the products I use. It also includes a cool time-lapse, let me know what you think!
I went to my local 1/4 mile drag strip to get some baseline results before I start diving into maintenance and modifications!
It was my first time launching or racing one of these cars with an automatic transmission. Definitely a learning moment, especially after getting used to my 750whp manual 135i. Two completely difference experiences! It was hard to tell the 335i was even doing anything because the stock exhaust is so quiet
First-ever pass down the strip netted me a 14.71 at 95mph. Not great. I foot-braked the car and wasn't sure how high the stall would let me go before starting to spin the rear tires.
For the second pass, I left off idle thinking that might help. It didn't. Lost a tenth to the 60ft, but seemed to go down the back half of the track faster. The car was a lot cooler on this run as it didn't heat-soak in the staging lanes like it did on for the first run.
I've been wanting to test the accuracy of my Dragy device, so I had it on during my first two runs. I was impressed to find that it was within 0.03s and hit the MPH on the head! Take a look at the Dragy results below compared to the actual slips and you'll see each measurement is almost spot on. It's an awesome little device for measuring all sorts of stuff. 1/8 mile, 1/4 mile, 1/2 mile, 0-60mph, 60-130mph, etc.
Since the Dragy was so accurate and the track was packed, I decided to hit a couple backroads on the way home instead of waiting in line for 1hr per pass. For my third attempt, I held the e-brake along with the foot brake to stall up the RPMs. Once I was ready to go, I released both brakes and it resulted in a much better launch.
Unfortunately, the tires spun on my first street attempt because the tires were cold. So I did a u-turn and went right back to the same spot and did a 4th run after warming the tires up. Same exact launching strategy and the tires hooked, resulting in a better 60ft and much better ET than my original 14.7.
All passes were done in sport mode, without manual shifting. I let the car automatically shift for me to keep things consistent. I probably could've squeezed some faster times out of it if I shifted earlier to keep the car in it's powerband. I can feel the boost tapering off up top being stock.
Best of 14.31 @ 97mph leaves a lot of room for improvement. Next step is some much needed maintenance. The car has 140k on it and has never had a walnut blast (to my knowledge), and it could use some spark plugs/coil packs.
Check out the video of my runs, you'll get an awesome POV-style view of me going down the track
Well, I think I figured out why the car couldn't eclipse 13's in the 1/4 mile! I couldn't believe what I found after removing the intake manifold!
After loosening up some of the carbon with a pick...
Then after one pass of walnut blasting...
Lots of walnuts and manual scrubbing later...
I even cleaned up the intake manifold ports because those were caked with carbon as well. You can see the cleaned port on the left and the dirty port on the right.
It was a lot of work, but totally necessary. If you want to watch my whole process with more of a DIY/How-To style, check out my YouTube video. It also has some more information and a drive at the end showing the power increase/restoration.
Love the detail & time you take- keep up the nice work Jake
This week I changed the spark plugs and ignition coils and wanted to shed some light on the process. I filmed an in-depth video and wrote a guide to help others properly replace, gap and install their new plugs & coils.
I'm in love with the BMS spark plug gapper tool, wish I had it a long time ago. Can't wait to use it every time in the future for both my 335i and 135i. If you're curious how it works, I walk through the process in my video above.
I even used my Dragy to get some real-life performance results before and after swapping the plugs & coils! I did a 0-60mph run before and the best result I could achieve was 5.71 seconds. After installing the upgraded parts, I went out for another run and was able to knock it down to 5.53 seconds!
I guarantee if you watch the video or read my complete blog post, you'll learn something that you didn't know before. Either way, let me know what you think!
great, I hope you could reach 11 sec stock turbo ... keep it up
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW M2LPower 10.18@136mph
Hopefully you felt as big of a difference as I did!
Very true statement. The car was "misfiring" on boost onset and kicking a check engine light. Misfiring because it was running so rich with the intake ports all chocked up and still getting the same amount of fuel.
Did you notice that cylinder 1 was the most clogged and each cylinder back was less and less dirty?
No, all of them were pretty bad with no rhyme or reason.
Not a huge update, but I installed some LUX H8 LED angel eyes. Upgrading the angel eye bulbs are one of my favorite appearance modifications you can do for these cars. They’re relatively cheap, easy to install and greatly improve the look of any BMW.
I have the same set in my 135i and they've been holding up great for years. Very white, very bright, I wouldn't go with anything else. For anyone interested in the process, I wrote a step-by-step installation guide with more photos, etc.
This car came with a JB4 installed so I quickly added a bluetooth connect kit. This allowed me to update the very out of date firmware and gives me the ability to log and monitor everything from my phone. I have the same kit in my 135i and I love it.
I also stumbled upon a pretty cool app called Log Dyno. It allows you to upload a log and spits out a dyno graph. I was skeptical about how accurate it would be but it seems very close. As long as you enter the proper data and settings, it works very well. I filmed a complete video showing exactly how to use the app if anyone else is interested:
I did one log in map 0 (stock), and one log in map 1 with a small tapered boost curve.
The dyno graph exactly matches the boost curve and the numbers seem on par with other results. In my first-hand experience, the stock numbers are dead nuts on with wheel horsepower results from actual dynos as the N54 is rated at 300/300 crank horsepower.
For anyone interested in trying it out, I'd be curious to see others' results:
That being said, I bought some used index 12 injectors for the car because the current original injectors are leaking. Bad idle on cold start, wet plugs, black smoke, etc. Going to do a DIY on these soon... then the modding begins.
Been using the Log Dyno app for a little while and it’s awesome! Where did you find used index 12 injectors and how much where they if you don’t mind me asking?
I found them on eBay for $650. Offered $550 and seller accepted. As you can see, the one on the far left has a bent alignment tab, which has since broken off completely. But I'm told this is okay and it's only so you install them in the proper orientation.
As I begin to increase the boost in this car, the first thing I want to address is the charge pipe. The stock plastic charge pipe is prone to cracking and breaking with increased pressure. Since I don't want to be left stranded on the side of the road, I decided to upgrade the charge pipe right away.
There are a ton of options on the market for charge pipe, blow-off valves and diverter valves, but I chose the BMS aluminum charge pipe with a TiAL BOV. In my opinion, this is the best bang-for-your-buck option available. It fits great, has a durable finish, two NPT bungs, includes all the proper hardware and a genuine BOV.
If you're starting to mod your N54, I wrote a detailed article about what to look for when shopping for a charge pipe. Check it out here: The Ultimate BMW N54 Charge Pipe & BOV Guide
I also filmed a video demonstrating the whole installation process with a few tips/tricks along the way.
I'm very satisfied with my choice and don't think there is a better option at this price point. No more worrying about the stock pipe exploding, plus the sound of the TiAL valve is perfect. Now I can continue modding this car!
