(#3776)
Tech5's Avatar
Tech5 Tech5 is offline
Car: 08' BMW 535xi
Default 03-19-2019, 06:55 PM
Complete nuwbee here, trynna understand what I'm doin lol. MHD back end flash is permanent change in DME software, right? Once you flash, is there a way back to stock performance? For couple months now I've been running hybrid turbos with jb4 map 5. I'm not getting any codes or misfires but understanding that with twice of boost over stock and fuel to match that boost I gotta do something with timing. Thinking to do MHD back end flash but looking to have a plan b just in case something goes wrong. Thanx guys
mb443 mb443 is offline
Car: 08 E90 335i
Default 03-22-2019, 12:01 PM
I flashed to PUMP a few days ago. Car is running awesome, feels so much more like stock tune in consistency compared to JB4 alone. I've been going through a lot of fuel
Same questions as the others here. What is the specific difference between PUMP and PUMP_USA maps? Is there potential for noticeable performance differences between the two?
2008 E90 335i 6MT Sport A22, no iDrive
FBO | JB4 G5 ISO + Pump BEF | Turbosmart DualPort DVs | 335is/550i clutch | RE trans mounts, shift bushings | Phoenix CP | BMS DCI, OCC, diff lockdown, etc | ZHP knob | Shiftek DSSR | PS AS3+ on stock 162s
StormShadow335's Avatar
StormShadow335 StormShadow335 is offline
Car: 355i
Default 03-22-2019, 04:17 PM
Originally Posted by deafcon
New guy here, both to the forum and BMWs in general. I just bought a completely stock 2008 535i with blown turbos. My brother has already rebuilt and reinstalled the turbos on two 335is. I'm confident we can get the car put back together, but I need some tune advice.
On the way are a JB4, BMS DCI, VRSF 7" intercooler, VRSF 2" inlets, VRSF outlets, *********, and a pair of ebay TD04 hybrids. With those parts in mind, will one of the stock JB4 tunes be safe to drive until I can get an upgraded LPFP? If not, is there a backend flash that will be safe? I'm not looking to wring all the power I can out of the thing until I get a fuel pump, charge pipe, and bov installed.
Have guys been running the ebay td04's? If so, what's the longevity? Can they be trusted to not overboost, leak oil, smoke? Kinda curious because I'll need turbos soon.
2008 335i 6MT, Doc Race Precision 6062 GEN2 kit, JB4 ST BEF, BMS Meth & dual OCC kit, Helix hpfp, Boost Concepts Stg 2 lpfp, VRSF 3.5" exhaust, & FMIC, ER CP, HKS BOV, 550i clutch.
zr666zr's Avatar
zr666zr zr666zr is offline
Car: z4 35is
Default 03-30-2019, 11:30 AM
Hi, Terry.
At first, thanks for your job!
I installed your latest back end flash (INAOS Pump) on my 2010 z4 35is using BT cable and bbapp 1.3.3.1
After that i get codes for low pressure fuel sensor!
But my car don’t have low pressure sensor... I think it’s some flash settings.
Is it possible to fix it somehow???
2010 BMW Z4 35IS EUR | DCT | JB4 | AR Design *** |
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 03-30-2019, 05:58 PM
Usually when BMS separates products/software/features by US and ROW, its due to some kind of emissions reason. That said, if you are in USA, start with the USA version, it will perform the same.
DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 04-03-2019, 08:21 AM
When using a custom BEF, do the maps do anything other than change the boost target?
Tech5's Avatar
Car: 08' BMW 535xi
Default 04-04-2019, 01:13 PM
How do you guys attach logs here?
Tech5's Avatar
Car: 08' BMW 535xi
Default Jb4, backend flash. - 04-04-2019, 01:45 PM
Hopefully I made this post and attachment correctly. Been running jb4 for a few months now did a backend flash. Can someone look at my log. I think my avg ign. Is to high. What could be causing that?
Thanx guys
Hybrid turbos, 2" inlets, DCI, OCC, 2step colder plugs, upgraded PCV, stock **. Catback straight pipe.
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 04-05-2019, 07:52 AM
Thanx guys
Logs and support questions should go here: Support Log Review - N54Tech.com - International Turbo Racing Discussion
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default Anti-Lag not working - 04-05-2019, 02:12 PM
I just purchased the antilag chip and install kit for my bmw n54 automatic 2007.
Jb4 wight bluetooth
Mhd back end flahs with this update installed ( 02/07/19 Map Release )
JB4 (map 5) up to date, with these 2 files : File Type: hex N54_G5_MAC_135_T4.hex (80.6 KB, 411 views)
I have the 2 step working, but not the anti-lag.
In neutral nothing happens, it revs up until redline.
While driving, volume down, gas pedal 100% it will rev around 4000rpm until I release the down volume button.
The rpm doesn't bounce to do the anti-lag as seen in the video?
What am I missing?
The back end flash is activated in the jb4, am I supposed to click something somewhere in the MHD to activate the anti-lag?
Thank you
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 04-06-2019, 10:04 AM
as far as i can tell, the pump_usa does not get rid of my exhaust codes if you know what i mean. the other pump does. no one seems to want to answer what the difference is and i think it might be related to this as bms did get in trouble with CA before a while ago
2009 335i e92 n54 | FBO | JB4 | e85 flash |
LuSt4Boost LuSt4Boost is offline
Default 04-11-2019, 06:42 AM
I already have the JB4+BEF setup from when I was FBO+Meth. I just installed my Pure S2 turbos, is there anything else I need to do to drive the car safely? Would Map5 suffice until I get a custom tune?
deezy's Avatar
deezy deezy is offline
Car: 2010 135i
Default 04-11-2019, 07:23 PM
I've read through the recent posts and still didn't see any clarification on the difference between the pump and the pump_USA file.
Can someone shed some light on what the differentiation actually is?
Any insight is greatly appreciated
135i N54
6266 DocRace - JB4 - MHD - Fuel-It! Stage 3 - BMP PI - PR coils - VRSF IC - Active Autowerke Exhaust
07murderedcoupe 07murderedcoupe is offline
Car: 07 345i
Default 04-12-2019, 06:04 PM
Has anyone ever had issue getting the burble option to work in the BEF? Car has stock exhaust except for being Catt less. It’s on the Pump_USA bef
Default 04-12-2019, 06:25 PM
USA has all the required DTML and emissions components in place.
Car: 07 345i
Default 04-12-2019, 07:03 PM
Terry how much ethanol can I run on the pump BEF? Just trying to figure out how to get to gas station and home so can flash the appropriate bef map lol.
Default 04-19-2019, 09:16 AM
It's really a matter of how much fuel pressure can your system maintain at high 11:1 AFRs.. Normally, up to E30 is workable. Sometimes more.
wlld1984's Avatar
wlld1984 wlld1984 is offline
Car: E90-N54
Default 04-19-2019, 10:35 AM
I have a 2009 z4 35i with MSD81 INA0S factory flash.
After flashing my DME with INA0S BMS Back end flash, I'm now getting a 29F3 code, which is a faulty low pressure fuel sensor error,but my car doesn't have a low pressure sensor!
E90 335 AT|JB4 G5 ISO |TREBILA flash|anti-lag|VRSF 7"HD FMIC|N20 TMAP |BMS METH|3" **|walbro 455|Forge DV | RB PCV |DINAN oil cooler|XHP stage 3|MMP PI|MMP inlets|MMP outlets|MMP turbo
Carlos Carlos is offline
Car: '07 335i Convertible
Default Which Hybrid E85 to BEF? - 04-21-2019, 11:03 AM
About to flash after installing PI's, Fuel-it Stage 3 and external regulator, and 1K turbos on 100% E85.
Whats the difference in the between the 02/07/19 Map Releases:
JB2_I8AOS_HYBRID_E85_PI_LOWTIMING_NOSPOOL.bin and JB2_I8AOS_HYBRID_E85_PI.bin
'07 335i, FBO, 4bar TMAP, PI's, Fuel-it Stage 3 and external regulator, and 1K turbos on 100% E85.
Default 04-21-2019, 01:37 PM
Foud IT!!
"Great conservative option for hybrids, especially on lower grade fuels or when you don't need every last HP."
Seedless Seedless is offline
Car: 2008 535xi
Default 04-29-2019, 05:15 PM
So you know how it says specifically in step #9 if you lose your original .bin you will have a headache later...currently experiencing that headache as Iím trying to get my car emissions tested with the pump gas back end flash currently In the computer and the vin in the computer is different from the vin on my registration card
So I guess my question is what are my options?
Is there a way to change the vin in the current .bin to my vin number?
Or is there a way to get my original flash somehow?
Iíve tried searching everywhere and have lost hope
Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 04-29-2019, 05:21 PM
Doesn’t mhd keep a backup?
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
Car: 2008 535xi
Default 04-29-2019, 05:35 PM
I used the bimmerboost app and had a backup stored on a flash drive and on a PC that my ex girlfriend has that there is zero chance of getting back
tks535i tks535i is offline
Car: 08 535i 6spd
Default 04-30-2019, 05:36 AM
When is a USB C cable coming out? Would like to flash but new phone is not liking a micro usb to type C adapter.
Dayton, Ohio
2008 E60 535i 6speed Sport Suspension
JB4, MHD BEF, DCI, D0wnp1pes, 7" VRSF FMIC, CP and BOV, H20/Meth Injection, Stage 2 LPFP, OCC
Woode30 Woode30 is offline
Car: 2008 e92 335i
Default 05-02-2019, 10:22 PM
What MHD backend flash map/tune would you recommend for fbo, jb4, with meth kit and running e30?
