victor247 victor247 is offline
Car: 2008 335i Vert
Default 10-18-2018, 03:22 PM
Sorry guys, For what ever reason I want getting the email notifications about the tool. Yes, I still have it and rent it out. My bad.
2008 335i E93 Single turbo
codesx's Avatar
codesx codesx is offline
Default 10-19-2018, 10:11 AM
*Subscribed*
I may be doing this shortly myself. Shredded serpentine belt and all.
Moos209, any chance you did a write up?
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
rnave1 rnave1 is offline
Car: 2011 BMW 335ix
Default 10-20-2018, 06:46 AM
I'll be replacing my rear main seal soon, hopefully this week. Is the tool still available to rent?
Car: 2008 335i Vert
Default 10-22-2018, 10:32 AM
Yes it is. PM me.
sportinsflying's Avatar
sportinsflying sportinsflying is offline
Car: 2009 335i
Default 12-17-2018, 10:54 AM
Very short tap screw. Screw into old seal then use pliers to pull. Lube new seal and use a big enough socket or cylinder to hammer in at once to go in evenly.
did you know the specific size socket you used?
TIA.
Woody
2009 E92 with BMS DCI, 2nd catalytic delete with a JB4
2016 F800GT
slinkygn slinkygn is offline
Default 12-28-2018, 05:57 PM
I own the tool, but am still having issues. Has anyone run into the issue of the extraction tool (the new version, where the whole thing screws in) just pulling out the rubber face/lip of the seal but never catching onto the body of the seal itself? It almost seems like the thing doesn't have anything sufficient to bite into to anymore, and can never engage well enough to pull the seal out. I can't figure out any other way to extract it, either, at least not without marring the mating surface on the block itself.
Car: 2008 335i Vert
Default 12-28-2018, 07:14 PM
You might need to use the drywall screw method. Drill a small hole in the metal part of the seal, Then screw in a drywall screw into it and pull on it until the seal comes out. I would use a few screws at a time to make sure enough pressure is applied evenly, or it will just strip out the holes you made and you might be left with nothing to grab onto after.
Default 12-28-2018, 07:38 PM
I guess what I'm saying is, I don't know that there's any surface left to screw onto. I realize that's probably not super clear - I tried to take a few photos to see if it would help. If I'm missing something obvious (totally possible!), could you point out where I'd be inserting screws?
Default 02-16-2019, 11:19 AM
The rest of the sleeve finally came out -- 3 hours of prying at that sucker. It feels like the process marred some of the housing surface (not the crank itself, it's intact; just the "outer" surface that the seal sleeve was stuck against in the photos). Anybody know how much of a problem I might be looking at? Should I be filing/sanding down any mars or burrs, or is that likely to make it worse? And if so, how much -- are we talking baby-butt smooth or it'll leak, or as long as there aren't any big jags or peaks?
Car: 2008 335i Vert
Default 02-23-2019, 06:32 AM
Did you get this figured out?
I would imagine the outer part of the block is where you might have added some scratches/gashes in the aluminum as you were prying that seal out, I believe you should be fine, as long as it wasnt deep and not the full width of the seal.
teggei2 teggei2 is offline
Default 02-23-2019, 07:22 AM
I have this tool available for sale if anyone needs it. BMW N52 N53 N54 Oil Seal Remover - Baum B119180PLUS
Default 02-23-2019, 07:23 AM
codesx's Avatar
Default 02-27-2019, 04:28 PM
Fire me a PM with the price?
I live in Ontario, Canada.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Edirty978 Edirty978 is offline
Car: 07 335xi 01 S4 90 300zxtt
Default 03-13-2019, 12:41 AM
Is that serpentine belt lodged into the crank seal?? If so pull the oil pan and remove all the pieces and also check that your alternator bearing pulley is not siezed ... if its seized your belt will rip again
RichiE60n54 RichiE60n54 is offline
Car: 09 e60 N54
Default 05-18-2020, 05:35 PM
Originally Posted by Moos209
Where are you located?
Think I could rent that tool from you bro Iím located in El Paso Texas
Car: 09 e60 N54
Default 05-19-2020, 09:34 AM
Still renting the tool
Out my man ? Iím in El Paso Texas
JLBimmer's Avatar
JLBimmer JLBimmer is offline
Car: 2016 435ix GC
Default Specialty Tool Rental - 06-24-2020, 07:47 PM
There is a company out there that will rent you the kit for $63/week in US
BMW N40 N42 N45 N45T N46 N46T N52 N53 N54 N55 front crankshaft oil seal removal/installation kit - Specialty Auto Tool Rental
JL Bimmer
2016 435ix Gran Coupe
HRP Cold Air Intake, Charge Pipe, Turbo Up Pipe, Turbo Intake Pipe, BMS Intercooler, Axle Back Exhaust, JB4
H&R Springs, Sways, Strut Tower bar, 19"x10 Rotiforms, Too much carbon goodness
