(#2376)
Default Yesterday, 10:14 AM
Originally Posted by terrelltechsup
Oh don't you worry. I found it. One floor jack, one jack stand, one 10mm socket, 8 bolts and 1 pop rivet later. Thanks again for taking a look at it.
Default Yesterday, 10:16 AM
Originally Posted by P4RTYH4RTY
I've attached 2 logs; I started each log between 2k and 3k rpm in 2nd gear. I'm running map 3 with e30.
I don't know if this would have any affect, but when I uninstalled the fuel wires the first time around, I noticed a few of the internal wire strands had been pinched off when screwing/unscrewing them in; I ended up just reinstalling them as is. Should I cut the wire down so all internal strands are still intact? Does this make sense?
Thanks.
As long as the fuel wires are making contact that is fine. I see boost is limited in 2st gear so that is probably part of what you are feeling. You could try setting that to 0. Other than that I don't see any indications of turbo lag or other issue.
P4RTYH4RTY P4RTYH4RTY is offline
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default Yesterday, 10:23 AM
Thank you for taking a look.
Actually, I only have boost reduced in 1st.
Given that it should be getting more boost in 2nd, why do you think it's not?
Default Yesterday, 01:48 PM
Set 1st gear to 0 as it goes by road speed currently rather then gear.
BMS Fanboy
Default Yesterday, 02:31 PM
Ok, Iíll log again this evening.
Thanks.
thuglifesk thuglifesk is offline
Car: Kia Stinger GT2
Default Yesterday, 06:17 PM
Thanks for checking the logs Terry. So should I stick to Shell 91 or try Petro 94 for better readings?
Default Yesterday, 06:18 PM
I'd stay with the 91 appears to be working fine to me.
Default Yesterday, 07:04 PM
Got in 20 of our unique Stinger zero-service OCC! Get them while they are hot.
https://burgertuning.com/products/bms-stinger-occ
Damn these sold out quick.......when will they be restocked again?
Default Yesterday, 07:36 PM
Yes we only made 20 the first batch... We're going to wait for people to install them, make sure everyone is as happy as we expect, then we'll do a larger run. Once we start will take around 2 weeks to complete. So maybe 3-4 weeks out realistically?
Default Yesterday, 09:52 PM
I was just thinking of getting the ADD W1 dual catch cans but this seems like a superior product, specially the "no maintenance" part. ill be keeping an eye on this.
