(#526)
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 07-09-2019, 06:02 PM
I've seen that one before from time to time. I think it's tuning related but not exactly sure how yet. Never comes up on map0 right? It should be an easy fix once we narrow it down.
Able to pull your freeze frame data on it with an OBDII tool?
Hey Terry, Ill try tomorrow. I pulled the JB this afternoon. We'll see what happens tomorrow. Its a hard code though, something constantly triggering the code. Might be a sensor or something. No catch can btw, i have an 18, no need for one.
Side bar: Any updates for the wifes X2? Would love to get steering wheel menus running.
Default 07-10-2019, 09:52 AM
The first test is to see if code comes up on map0 to know if it's hardware or software related...
On X2 not sure if we have dash active for those yet, but ask in the platform thread and we can check in to that!
Abyssf150 Abyssf150 is offline
Car: 2019 f150 2.7 Ecoboost
Default 07-13-2019, 03:41 PM
OK so as stated above last week I got a p0400. I had the JB4 install for about a week with no problems. Then I added the JB4 connect kit last Friday upgraded to the latest firmware and switched to map 2. Ran fine Friday and Saturday morning. Saturday afternoon I get a check engine light. Check the code p0400. Cleared the code swiched back to map 1 made it home with no issues or lights. Sunday morning no issues, Sunday afternoon CEL p0400 again. That when I first messaged you thinking it might be firmware related switched back to version 3 firmware. Didn't drive Monday or Tuesday. Wednesday night heading to the airport CEL again p0400. Switch back to map 0 drive to airport and back about 80+ miles no problem. Thursday headed to a friend's place still on map 0 check engine light again P0400.
Removed JB4 all together so I can take it to the dealership for warranty work. So far I've driven another 80 plus miles without the JB4 and no engine light. Is it possible the Bluetooth connect kit is the cause since that's when problem started? I know I'm grasping at straws here. Hoping the engine light will pop up without the JB4 being installed so it can be ruled out.
Default Yesterday, 08:28 AM
I've seen p0400 before on previous firmware versions so I'm sure it's JB4 related somehow, but it's strange you get the code on map0. It's easy to remove the blue tooth connection just to see if it's somehow related.
Default Yesterday, 08:38 AM
Assuming you meant strange I did get it on map 0.
But so what I'm hearing is the code is JB4 related and not my truck actually having an issue?
Default Yesterday, 09:08 AM
If it's not coming up with the JB4 removed then must be related somehow.
