akadic10 akadic10 is offline
Car: 2017 Honda Civic Type R
Default Sharing my type r map 1 so far - 07-08-2019, 05:29 PM
Hey, received my unit today but only had a few minutes to drive with perhaps one solid 3rd gear pull. I'll do some more this weekend.
Quick feedback, it is very easy to install and map1 is fairly noticable.
I live in north Florida, use 93 pump gas and always fill up at Shell. I also have a KN drop in filter but I can't imagine it will have an impact at all.
Let me know if this is enough for me to be promoted to map2
Default 07-08-2019, 07:12 PM
Short run but seems ok to me so far!
Default 07-11-2019, 05:19 PM
Another map1 with a solid 2nd and 3rd gear pull.
As promised I will upload some more this weekend.
Default 07-11-2019, 07:35 PM
Thanks, looks fine. No logs needed unless an issue comes up.
Default 07-12-2019, 07:15 AM
Does that mean I can go to map2?
Default 07-12-2019, 05:08 PM
For the typeR I normally suggest staying on map1 due to fuel pressure issues. You can try it but if you have any issues just drop back down to map1.
