(#776)
Jefflee Jefflee is offline
Car: c450
Default 06-16-2019, 02:42 AM
For installing BCM
Can those aspects be adjusted?
Default 06-16-2019, 12:21 PM
Yes the mapping is adjustable.
Directions for installation here: N54Tech.com - International Turbo Racing Discussion - View Single Post - Mercedes C300 / C400 / C450 / C43 W205 Stage1 JB4
Car: c450
Default 06-17-2019, 03:58 AM
Can provide c300
Jb4 installation guide?
Car: c450
Default 06-17-2019, 09:48 AM
Cbm
How to make the signal shrink? How to adjust?
baccart88 baccart88 is offline
Car: C43
Default 06-17-2019, 10:57 AM
how does this look?
Default 06-18-2019, 08:37 PM
Originally Posted by Jefflee
Can provide c300
The C300 JB4 install guide is on our site, it's the same guide as the C400/C43.
Originally Posted by baccart88
how does this look?
The log is too short to really evaluate, try to capture something longer!
MatthewJ MatthewJ is offline
Car: C400
Default 06-20-2019, 12:45 PM
Terry or Payam,
Could you please let me know if you see anything i need to adjust with this map 6 setup? C400, E30 mix, BMS intake, hot and humid AF outside. Timing is up there, boost seems to hold where i want it and i set FOL to 65 to try and get trims down some. First gear doesnt like it though, it feels like it pulls a bunch of boost and short shifts second then the boost comes on hard. Have max boost 1st set to 5.0, should it be higher?
Default 06-20-2019, 06:19 PM
Originally Posted by MatthewJ
Terry or Payam,
Boost, timing, and fueling all look good here. I wonder if you wouldn't benefit with the BCM given the high target? Worth trying I think. You can always return it if it doesn't wind up helping the car go faster!
marcrpoirier marcrpoirier is offline
Car: C400
Default 06-21-2019, 04:42 PM
Hi Terry, quick one !
My Friend ordered a JB4 for his car BMW today from Canada, he had a different ship To address than itís bill to. He was asked to provide additional details Photo ID... is this the normal process ? Just to confirm itís not some phishing/hacking technique from an illegitimate organization
Tjs
Marc
Default 06-21-2019, 06:25 PM
Normal process, there is a secure link he will get for addl info to confirm order, when billing/shipping address don't match AVS process.
Car: c450
Default 06-24-2019, 05:28 AM
Hi!
Can understand and tell me c300
A/b/c installation guide?
I am a blue version of jb4
Default 06-24-2019, 10:34 AM
Hi!
Upload a picture of your engine bay and I can help you move forward.
What is blue version of JB4? Did you purchase this from us?
Car: c450
Default 06-24-2019, 09:41 PM
Yes
Car: c450
Default 07-02-2019, 08:44 AM
Can provide more reference to the map6 adjustment method?
BigTurboC4 BigTurboC4 is offline
Car: C400
Default 07-10-2019, 08:11 AM
Roast me if you will, but in lieu of searching whilst I have no time....On the newer harnesses, where does the green wire plug to? C400 btw.
Default 07-10-2019, 10:01 AM
It's optional, attaches to the fuel pressure plug under the factory airbox on the driver side. Normally only used for E85 mixtures or really aggressive setups.
Car: C400
Default 07-10-2019, 11:01 AM
I remember it being optional from the install. A user over on mbworld suggested using it and then graduating to a more aggressive map than map 2 if the fuel trims looked okay.
Savvy Savvy is offline
Car: C300
Default Need help with connection A - 07-11-2019, 07:47 PM
I can't seem to be able to connect connection A or am i connecting it to the wrong one? kk - Album on Imgur
