(#651)
KjKeyz KjKeyz is offline
Car: 335XI 08'
Default Yesterday, 01:23 PM
Originally Posted by THE BEAST
Mine used to do all that on T1.
Then that got fixed but my car drones on BETA firmware and maps change around. Say I do 20 psi on map 6, and 23 on map 7 and 26 on map 8...ill log say map 7, but will reflect boost curve of map 6. The log will clearly show map7 but record the settings of another map.
Any of this happen to you ?
Oh and base wgdc will jump around at times.
What was the fix for you when on T1?
2008 335xi | JB4 | VRSF Charge pipe | VRSF 7in. HD intercooler | VSRF Aluminum Outlets | VRSF Down P!pes | RB silicone inlets | BMS Dual cone intake | Turbosmart Kompact Dual Port BOV | RB PVC valve | OCC | RB 2+ Turbos
Car: 335XI 08'
Default Yesterday, 05:35 PM
So I went to version 15. Tried to save the settings and had no luck at all. As soon as I hit save and go to check the values of the User Adjustment settings the Map 6 Boost is all changed and the boost safety is also changed.
I've also been having an issue where the gauges are reporitnf info that may not be accurate. For example, it'll show .2-.4 PSI for boost on idle at random times.
Using the JB4 app on Android
Car: 2008 E93
Default Yesterday, 11:44 PM
I went back to previous firmware.
Waiting on Terry to figure this out.
Car: 335XI 08'
Default Today, 04:49 AM
I wish I could do the same but it seems the earlier version is no longer available for download.
Thunderstorm1250
