STUARTS STUARTS is offline
Car: M240
Default New Member Log - 03-03-2019, 10:51 AM
Hi All
New Member with M240 2017
Just installed JB4, Bluetooth Connector & D***T D******E.
Car running standard JB4 settings & logged in 4th gear.
Shell V Power UK Fuel 99RON.
Trying to understand & learn!
Any feedback would be very much received.
Regards
Stu
JBoe JBoe is offline
Car: M240i
Default 03-05-2019, 09:29 PM
Welcome to the forum. We really need a log showing one long pull from 2500rpm to redline, in either 3rd or 4th gear. Otherwise we can't give a 100% evaluation. From what I see though, timing and trims look ok. The throttle closures are likely from the ********, which is leading to some overboosting. You may have to get the EWG harness to correct that and smooth out the closures.
Car: M240
Default 03-06-2019, 05:06 AM
Many thanks for the advice. I have a EWG harness to fit this evening. What map & settings do you recommend? All my user adjustments on the JB4 are completely standard.
Regards
Stu
Default 03-06-2019, 11:31 AM
Regards
Stu
Get a log first without the EWG connector and we'll evaluate it.
The EWG connector is mostly needed when going with higher boost levels with methanol/racegas.
Car: M240
Default 03-06-2019, 12:32 PM
Thanks Payam. I will do that.
Car: M240i
Default 03-07-2019, 12:51 AM
Absolutely… stick with what Payam is saying. It's always best to adjust within what the JB4 can do as is. Then, if needed, add in the other components. With exception of fuel and WMI settings, I'm running all stock/standard settings as well.
Car: M240
Default 03-11-2019, 12:38 PM
Finally able to attach a new log due to bad weather! Many thanks in advance for your advice and time to look at this.
Car: M240i
Default 03-13-2019, 10:56 PM
Loos good to me. You could try Map 3, but it looks like map 2 is your max without additional fuel. (FF wires or WMI)
Car: M240
Default 03-14-2019, 07:44 AM
If I try Map3 do I need to attach the EWG Harness?
Car: M240i
Default 03-16-2019, 10:31 PM
Not from what I see.
