(#426)
Default 06-24-2019, 07:43 PM
Log map1 to start.
Hondero98 Hondero98 is offline
Car: Honda Civic
Default 06-24-2019, 07:47 PM
Terry, I have already run with map 1,2 and 3. Right now I use map 3 and my car runs very fast but I would like to know if I can use map 4 and 5 with 93 octane petrol from Mexico Mobil. I have no problem
MarcoTypeR MarcoTypeR is offline
Car: Honda Civic Type R
Default 06-24-2019, 09:19 PM
Is there a specific timestamp on the map1 log you noticed the issue come up so I can focus in on the details?
Can you Look at 1700, 3150 and 4120. I would only notice at on Area on track, when in 5th WOT. I would get one or two jerks like running out of gas for a second
Alextyper Alextyper is offline
Car: Civic type r
Cool New to jb4 - 06-25-2019, 03:33 AM
What’ up guys am new to the jb4 I love it so far and I been looking at
All these posts it’s been really helpful.. I have A type r I just put it on map 4 30 percent e85 four gallons and the rest 93 oct is this safe ??
Austype R Austype R is offline
Car: Honda Civic type R
Default 06-25-2019, 08:22 AM
I would advise you to log map 1 and gradually build up once it has been properly reviewed , As type R has fueling issues it struggles with e85 blends. I can't believe nobody has done logs with ethanol yet but run it anyway without really knowing what's going on in there.
Default 06-25-2019, 09:01 AM
Our testing with the R showed fuel pressure issues even on map1 with enough E85. So I'd have to see your specific logs for tuning advice! Some cars seem to be able to get away with it.
Default 06-25-2019, 09:03 AM
Just sort of scanning along I can't see anything obvious in the logs. One test might be to use map6 to enter say 2.0 across the board and evaluate under similar conditions. Could it just be spark blow out from too large of a plug gap?
stuffle69 stuffle69 is offline
Car: 2019 type r
Default 06-27-2019, 10:12 AM
Where do we send our logs too?
Default 06-27-2019, 10:39 AM
You can post the CSV file here for us to evaluate.
At the bottom of the reply box, click go advance. After that you will see a paperclip icon at the top. That's where you'll be able to upload the CSV file for us to check.
Car: 2019 type r
Default 06-27-2019, 10:50 AM
Terry,
Here's the log's 1st is 2-3 gear pull rest are 3-4 gear pulls feels like running out of fuel top of 4th gear running 93 oct map2 have k@n drop in filter ,prl intercooler, prl catted ******** and frontpipe outside temp 80 degress
Car: 2019 type r
Default 06-27-2019, 10:51 AM
map 2
Default 06-27-2019, 11:09 AM
Fuel pressure seems to be holding up. raise the octane a bit so we can rule that out. Maybe a can of MMT based octane booster like Lucas or NOS race.
Car: 2019 type r
Default 06-27-2019, 11:12 AM
Ok will try that, everything else look good?
Default 06-27-2019, 11:49 AM
Yes looks OK to me in the logs
TatanR TatanR is offline
Car: Accord 1.5T
Default 06-28-2019, 10:28 PM
so, just picked up JB4 today. Installed and did some good pulls on MAP-1, at least i think. Set-up: Accord 1.5T stock. 91 octane and its about 101F here in AZ. Let me know what you think.
Im a newbie.With that been said any input helps. Thank You
Default 06-29-2019, 11:49 AM
Given the low octane and high temps doesn't look that bad. ~0.66KR is lower than I'd expect. I'd keep it on map1 though on the 91 as KR will probably work it's way up.
Yjmebs Yjmebs is offline
Car: 2019 Civic Type R
Default 07-02-2019, 01:24 PM
I just got the jb4 for my type r and I have a few questions.
1- Where in the app can you see which firmware you are running? I just updated to 1.04 but I was never able to see what version I was running.
2- I see screenshots with bar graphs. Where are they in the app?
3- IAT in the app. Is that before or after the intercooler temps?
4- Is it possible to show peak boost in the app?
5- Is there a recommended app for csv files? I can only open with excel.
6- I just ordered the throttle controller, any compatibility concerns?
Default 07-02-2019, 03:14 PM
1) Firmware and interface versions are on the user adjustment page under read only, towards the bottom
2) You can chart in the app, or via the windows JB4 interface software
3) After. TransTemp is "MAF" temp before intercooler.
4) I think it's an app option but you can ask Donnie directly in the JB4 mobile thread.
5) The JB4 windows interface, linked in the first post
6) Won't be any issues, we sell our own Honda pedal tuner as well for $179.
Default 07-02-2019, 03:27 PM
I ordered the Throttle controller from you guys today.
So am I on the most updated firmware? 1.04
jgklim's Avatar
jgklim jgklim is offline
Car: 2018 Honda Civic Sport
Default 07-02-2019, 03:29 PM
Peak boost - double tap boost gauge!
Default 07-02-2019, 04:32 PM
Yes!
Car: Honda Civic
Unhappy Problem - 07-17-2019, 05:31 PM
hello terry, i have a problem with my jb4 or the jb4 mobile. My car works well but sometimes the Target stops working and stays at 0. I already update my app and also the firmware and it stays the same. Could you help me solve this problem please? Tell me where to accommodate that or why do that, the car works the same but the Target stays at 0. Do you think it could be the app? or is it problem with jb4?:corazón roto:
Default 07-18-2019, 08:01 AM
Send a log when it's at 0, maybe you are triggering a safety system within the JB4.
