steeve13m steeve13m is offline
Car: 13 M5 DCT
Default POLL: F10 M5 JB4 Meth users what settings do you use? - 08-15-2018, 02:07 PM
Boost additive: 0-75 ?
Boost failsafe psi: <=30 ?
6-cyl timing logging: 0-6 ? (1 enables going over 10psi boost over stock limit)
any other settings you all modify?
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Default 08-15-2018, 05:59 PM
Depends what you're trying to do I guess?
Car: 13 M5 DCT
Default 08-15-2018, 08:27 PM
I am running the following settings on MAP 8 but curious to see what others are using for max power on 91/93 octane street setup?
Boost additive: 73
Boost failsafe psi: 30
6-cyl timing logging: 1
Default 08-16-2018, 10:37 AM
How do your logs look with that high of additive using 91 pump gas? We usually recommend a 40-50 additive when using pump and meth.
Car: 13 M5 DCT
Default 09-12-2018, 03:18 PM
Here's my latest JB4/meth Map8 logs... car runs very strong but I realized that if I dont use the meth often it appears air enters the meth piping and the pressure drops (meth reading goes below 50).......I have to purge the system using the JB4 app maybe 30 times and the meth reading goes back to 100.....thus I get full power back again....
