ezhamco ezhamco is offline
Car: F80 m3
Default E85 Spark plugs for S55 - 02-21-2018, 01:05 PM
Anyone Running E85 and wanting to go to a colder plug I have what your looking for. This is a factory OEM BMW part not aftermarket. I will also post this in the market place but wanted to make sure everyone saw this. Anyone interested can message me.
Silverstone_F80 Silverstone_F80 is offline
Car: 2017 f80 m3 zcp
Default 06-30-2018, 08:49 PM
What plugs and what is the gap ?
Trickcruiser's Avatar
Default 07-01-2018, 06:26 PM
Interested.
If you want to help people out, help people out and post the part number...
Payam @ BMS Payam @ BMS is online now
Default 07-02-2018, 08:08 AM
I'm running full e85 on my M4. I use the NGK 97506 Plugs gapped at .020" no issues at all and I'm making 560whp/620wtq. You can get them here:
http://burgertuning.com/N54_BMW_spar...t_adapter.html
Default 07-02-2018, 10:41 AM
Awesome thank you. What's all done to your m4 ? Are you FBO
Default 07-05-2018, 09:16 AM
Simple mods only, BMS Intake, JB4+BMS/MHD flash and full e85.
corbs09 corbs09 is offline
Default 07-23-2018, 09:21 AM
Sorry to bump an old thread, but is changing the plugs from OEM a requirement for the e85 back end flash? I am currently on oem plugs that were changed about 4k miles ago.
Default 07-23-2018, 09:29 AM
Corbs09, I ran the stock plug with e85 and didnt perform as well as it should have. I have recently changed to the Ngk 97506 with a 020 gap. Runs good no more stuttering.
Default 07-23-2018, 12:04 PM
Yes, I would advise to change them. When running e85 and higher boost most cars tend to break up. This will fix that issue and the car will run strong.
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 08-11-2018, 11:02 PM
I'm running the more stronger ones for Full E85 NGK SILZKBR9F8S they're used in Brazil in their Flex-Fuel cars
F80 ZCP DCT Tune Only | BM3 Custom F80Paul E85 100-200 5.9s, 60-130mph 6.7s "World Record Dragy Verified"
-HCP E60 60-130 7.3
-HCP E40 60-130mph 7.6s
-BM3 E30 OTS 60-130mph 7.8s
[ Pending: CTS Turbo D.P/CP/HE/Midpipe
WR X4 M40i CTSTurbo D.P/FMIC BM3 STG2 93 4.19s 0-60 | 12.4@109mph 1/4 m
$ECA $XRP $XLM $TRX $ADA
fast4d fast4d is offline
Default 08-14-2018, 11:43 AM
is this the secret OEM BMW plug made by NGK only available from europe? ;-)
Frikiton's Avatar
Default 08-14-2018, 12:39 PM
No secrets lol, they're just used in Brazil since those cars run Full E85 and need some tweaks for start up all year long it seems
-HCP E60 60-130 7.3
Default 08-15-2018, 11:26 AM
Just run the 2step colder NGKs gapped at 0.022" that are proven to work up to 700+whp on straight E85. No need to reinvent the wheel.
