(#1926)
Default 01-29-2019, 10:00 PM
Entirely personal preference or feel. There is a misconception that when using a JB4 you're locked in to whatever mapping style we choose to implement in the firmware so wanted to showcase the customization ability a bit.
Customtech Customtech is offline
Car: M4
Default 02-10-2019, 12:49 PM
Hi Terry, in our M4 race car we are limited BHP per ton, Iím looking to make 464 BHP max
I will be on the dyno in about a week, if I use your BEF what sort of power is that likely to make?
What map number would I use?
Default 02-10-2019, 02:17 PM
Sure, use JB4 map6 to set whatever boost profile you want to keep power where it needs to be!
TideMD's Avatar
TideMD TideMD is online now
Car: 2016 M4
Default 02-10-2019, 09:24 PM
Originally Posted by Customtech
... if I use your BEF what sort of power is that likely to make?
Iíve also wondered about this for my setup. Not looking for exact numbers, but just a relatively close WAG of the whp / wtq, since I donít have access to a dyno to truly see what the car is putting down.
2016 F82 M4 / Sakhir Orange / Black extended leather / Opti-Coat Pro
JB4 (stage 3) / MHD+BEF (BMS RACE v13) / NGK 1-step colder, 0.020" / BMC drop-in, carbon delete / Injen CPs / AR Design catt'd down / AA mid
LCI rear light retrofit / AutoTecknic front splitters / Mode Carbon High Kick rear spoiler / Status Gruppe rear diffuser
Michelin Pilot Sport 4S 265/285 35-19 / BMS ceramic black exhaust tips / Macht Schnell spacers - 15mm(f), 12mm(r)
Zimbo 2 Zimbo 2 is offline
Car: M3 CP F80
Default Yesterday, 03:42 AM
Hi, which spark plugs should I use if I've used JB4 and often drive Map 2 and 6?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
TideMD
