anti anti is offline
Car: E92 08 335xi
Default able to use ebay OBD cable for backend flash?? - 07-02-2015, 02:06 PM
I wanted to put the backend flash on my car (08 335xi), from what I've read I see the BT cable is $179 but there are cheaper cables on ebay I was wondering if one of these cheaper obd cables would be suitable to perform a backend flash or if there is any alternative to the "BT" brand $179 cable. I put down 417hp and 482 ft-lbs on the dyno the other day fbo minus stock exhaust no meth, trying to gain a few more with a backend flash
Thanks!!
`08 E92 6spd Sport;
JB4 G5 ISO
Active Autowerks FMIC
afe Intakes
ER CP/HKS bov
E50 - map 5
dynojet std 417hp 482 ft-lbs
vent boost gauge
c/f engine cover
bryce bryce is offline
Default 07-02-2015, 04:43 PM
Needs to be a BT cable. If you're lucky you can find a used one for $100. Or, go MHD
jwalker87 jwalker87 is offline
Car: 2008 335i
Default 07-02-2015, 04:56 PM
Check out the for-sale sections of any e90 forum or eBay. I picked up a cable with one of the 3 VINs used for $150 IIRC, so I still have 2 left for my 2 e90s.
You don't need the VIN cabapility for the BB flash, so even a single-VIN cable with the VINs used up will work fine!
2001 e36/7 M Roadster 5spd - stock-ish
2008 e90 335i 6spd - modified!
2011 e90 335xi 6spd - lightly modified
2011 e70 x5 diesel - stock (for now...)
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 07-02-2015, 04:59 PM
Bavarian Technic will remove VINs as well if you call them but as mentioned, the VIN lock doesnt happen when using BB software.
335is DCT
bnd's Avatar
bnd bnd is offline
Car: 2008 N54 E92 335xi
Default 07-02-2015, 07:29 PM
Thanks!!
If you already have the eBay cable and a otg capable android phone, I would recommend the mhd app, which is easier and cheaper.
2008 335xi N54 E92
MHD *****BQ
BMS JB4 G5 ISO
BMS Dual Cone
BMS OCC
VRSF 3" DP
VRSF 7" IC
VRSF CP
Tial Q BOV
Fuel-It Stage 2 LPFP
Alpina B3
NGK 5992
swat's Avatar
swat swat is offline
Car: 07 335i
Default 07-02-2015, 08:10 PM
+5000. And just get the one stop electronics cable for $99 and be done with it.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
