Choyo_n55 Choyo_n55 is offline
Car: E90 335i n55
Default Overboost with etanol. - 11-09-2019, 02:33 AM
Hi i have a little problem, i decided to try ethanol, in my country no e85 we have pure ethanol 99.8%. I started with mix e18-20, 0.6 gallons ethanol and 4 gallons gasoline (100 ron) logs were good, good ign good trims, but for the first time it happened that jb4 threw me out on map 4 and the reason was overboost ... i don't have a log at that moment but i saw the boost meter arrow show 20 psi. What advice would you give me if I need to raise the limit in user adjustment or? I have a log in which the car is ok I will attach it. thanks . I use map 5
2011 e90 n55, vrsf down pipe,cp,fmic jb4,AT xhp stage3
Default Yesterday, 02:32 PM
As you stated- we don't have a log of the overboost, try and capture.
If you wanted you can always raise your boost safety a bit, yours is currently set to 18, bump it to 20
How much is ethanol per gallon, just curious?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: E90 335i n55
Smile Today, 03:46 AM
Price? $ 4.46 according to the rate in my country ..
thanks for the advice
