Sir Jake Sir Jake is offline
Car: 2011 335xi E92
Default Error code 2C5830 from JB4 reading - 04-21-2020, 05:24 PM
Hello there,
I can't seem to find this code what it is, I just finished fixing a bunch of other errors due to a rat chewed wire. Cleared the codes and this is the only thing that JB4 is showing left
"2C5830 No Description Found"
Car seems to run pretty well, however need to look up how to use the JB4 again as it's been a few years the car sat for.
Thanks for any help. I'll connect up my barvariantech took this week if I still can't figure it out and see if it shows anything else.
Default 04-22-2020, 12:15 PM
If you clear the code- does it return?
Car: 2011 335xi E92
Default 04-22-2020, 12:17 PM
Hello Dave,
It does, I tried to clear it twice and it kept coming back up.
Now that was while it was running and didn't restart it during that time if that might help.
Car: 2011 335xi E92
Default 04-23-2020, 07:53 AM
Restarted the car after clearing code and this one keeps coming up for me.
Default 04-23-2020, 12:11 PM
If it’s not messing performance I’m inclined to say ignore
Car: 2011 335xi E92
Default 04-23-2020, 12:20 PM
Sadly the engine error comes up with reduced power. The car just doesn't seem to be running the way it used to.
Before I fixed a broken wire I'd guess the car ran like it had 100HP, now it feels like it's running at around 150-200HP but nothing like it used to have 2 years ago before it sat.
This is the only error code that seems to come up now.
I'll hook up my Barvarian tech up to it today and see if any more codes show up.
andrews013's Avatar
Car: 2013 E92 335i xDrive
Default 04-23-2020, 02:09 PM
Can you upload a log?
2013 E92 335i XDrive
JB4, MHD E85 BEF, EOS PI, Fuel-it Stage 2 LPFP, XHP Stage 3, XDelete Sport, 3.5 Bar TMAP, VRSF 7 HD IC, GFB DV+, VRSF D/P, VRSF CP, PE Mod, ST V1 Suspension.
Car: 2011 335xi E92
Default 04-23-2020, 02:12 PM
Hooked up my bavarian technic to it this afternoon and looks like I got the following error that could explain some issues.
300C Inlet-Camshaft sensor, signal high error will cause a warning light
2C58 Charge-air pressure control deactivation, charge air pressure buildup disabled will not cause a light
2C8A Bypass blow-off valve activation open circuit will not cause warning light.
Guessing it is most likely the inlet camshaft sensor error.
Car: 2011 335xi E92
Default 05-26-2020, 06:27 PM
Still getting these three error codes.
I've tried everything I can think of for the 300C error code.
I've replaced the camshaft sensor, this didn't fix the issue. so I replaced both vanos sensors and still same error.
Any suggestions?
Default 05-27-2020, 06:58 AM
Log?
Car: 2011 335xi E92
Default 05-27-2020, 09:59 AM
Log?
Don't believe I have a log of it I'll check my phone and see if JB4 saved anything.
I had it hooked up to my laptop with Bavaria tech.
Car: 2011 335xi E92
Default 05-27-2020, 10:01 AM
I've attached one of the logs here.
sicknick530's Avatar
sicknick530 sicknick530 is offline
Car: 2011 BMW e92 n55
Default 06-01-2020, 02:01 PM
Boost pressure solenoid.
Car: 2011 335xi E92
Default 07-21-2020, 03:42 PM
Thanks,
Do you think that this is causing the other error about the sensors?
"300C Inlet-Camshaft sensor, signal high error will cause a warning light"
Time to look at the boost pressure solenoid how to's
Default 07-23-2020, 05:24 AM
Need a better log
Car: 2011 335xi E92
Default 08-03-2020, 10:11 AM
Thanks,
I've taken two logs today on this and attached them here.
Thanks again!
Default 08-03-2020, 05:32 PM
Can’t view the files, can you trim the dead cells ?
Car: 2011 335xi E92
Default 08-03-2020, 05:38 PM
Not sure if the dead cells are at the end of it or not removed all the ones with 0's at the end. Hopefully that did the trick.
Helps to upload it.
Default 08-05-2020, 08:51 AM
Hey Jake,
I need a better log.
2k to redline, WOT, traction off fully off in 3rd.
Car: 2011 335xi E92
Default 08-05-2020, 10:02 AM
Thanks, I'll see if I can snag one like that tried today but hit traffic and the log seemed to show 2-3k then 3-4.6k
Feels like the car just isn't hitting any boost like it normally used to. Feels like non turbo
Default 08-05-2020, 04:15 PM
Will get ya fixed
Just log when you get enough space free
