Wbw2112 Wbw2112 is offline
Car: 2016 340i
Default JB4 Map 5 bad shift lag - 09-13-2020, 12:20 PM
Hello.
New to JB4 and BMW tuning generally. Glad to begin playing.
I have horrible shift lag on map 5. The car feels like it is stumbling over itself for what seems like .5-.75 seconds. Attached is a map 5 pull 2nd gear through 4th. DSC off.
Running all stock 2016 340i B58. New plugs gapped at .030 new ignition coils.
Firmware B58_17_T5
I have searched and found nothing quite similar and no solutions.
I did get a code on cyl 4 "Burning time out of tolerance." Replaced coil. No code since. Issue not resolved. Attached is post ignition coil replacement.
Side note: Poor power on map 1. I have .csv and graph of map 1 if requested. Map 1 has zero shift lag.
Could you all please advise?
Appreciated!
Car: 2016 340i
Default 09-13-2020, 04:10 PM
Potential rookie mistake.
Firmware v15+
"Map5: Absolute target map with peak of 22psi target (E30+ fuel) suggested for higher boost models like G chassis, Supra, and Z4. EWG required for proper control."
EWG arrives this week.
Please advise.
Thanks.
