HEBREWHAMMER0913 HEBREWHAMMER0913 is offline
Car: 540 G30
Default WASTEGATE FLAP SLUGGISH ON MAP 4 AND 5 - 08-25-2020, 07:08 AM
I just got the EWG harness on and decided run map 4 and try map 5 but every other day I get the 123511 Wastegate Flap Sluggish code. It had happened 4 times now. Is there something I need to do in the settings when running these maps ? Here is a datalog on map 4
I have ******* down pipe
Default 08-25-2020, 04:37 PM
Might be a firmware bug. Do you get the fault on v17 firmware?
Log looks fine.
Car: 540 G30
Default 08-27-2020, 10:22 AM
Huh Ill try that and see if it come on. I didn't try that firmware cus it said BETA
