Antimosity Antimosity is offline
Car: 2019 BMW 330i
Default JB4 Map 1 Log for 2019 G20 330ix - 09-20-2020, 10:27 AM
Did two pulls one in 3rd gear and one in 4th gear. Trying to see if everything fine.
I see throttle dropping while pedal is 100 in some instances and find it odd. I have an MST Intake but I never logged the car before installing the CAI so I'm not sure if the intake is causing this. Someone on the forum suggested the ECU may have been flashed prior to my purchase of the car.
VipinLJ VipinLJ is offline
Default 09-20-2020, 12:11 PM
Throttle drops happen in my car too, even when it was stock (Map 0). Do you notice it while driving?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
Car: 2019 BMW 330i
Default 09-20-2020, 04:29 PM
I don't really notice it at all no, it is a smooth pull to me. l almost want to ignore it since it only happens when trying to WOT which is rare in real-world applications. I've logged it cruising and the throttle is consistent.
Car: BMW G30 520i 2019
Default 09-20-2020, 05:38 PM
Do a pull in map 0 from 3rd and 4th gear man
Your DME is commanding boost of 20psi
That’s not a stock tune you’re running
Your timing drops to 0 are a concern
Default 09-20-2020, 05:41 PM
Check out Vipin’s logs
None of them show a DMEBT of over 16 psi
His logs have concerning timing drops too but not nearly to the same level as yours.
Car: 2019 BMW 330i
Default 09-22-2020, 10:08 PM
Can anyone comment on these logs? Each log has a pull from 3rd and a pull from 4th.
Running 93 octane and MST Intake.
Default 09-22-2020, 10:20 PM
You definitely have an aftermarket tune thats too hot
Same rationale as before
Your stock boost targets are well in excess of what a standard 330 would have and your timing retardation is really extreme
