ls3c6 ls3c6 is offline
Car: 08 corvette / 06 vue
Default 2020 m340i, 93 oc, stock car no ewg wire, maps 1/2 - 08-01-2020, 03:04 AM
Tried maps 1, 2 and 3. 1 feels the strongest, didn't end up logging #3 it felt the worst. Launch control does not work properly with JB4 installed but foot braking in sport plus dsc fully off seems to go ok.
Take a look at the logs and advise what I might change, E85 is available here.
VipinLJ VipinLJ is offline
Default 08-01-2020, 08:03 AM
In my g20 330i, map 2 felt the best till I updated to the latest beta firmware. Now I'm running map 3.
And why doesn't your launch control work? Mine works as it did before I installed the jb4.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
2016 BMW X3 xDrive28i
Default 08-01-2020, 09:00 AM
Bogged all the way through first gear, that's never happened on factory setup.
Default 08-01-2020, 12:23 PM
That's weird. Did you try switching to map 0 and seeing if it was the same?
Current:
Default 08-01-2020, 03:37 PM
Works ok on map1, it'll push through the brakes a little bit. I used this jb4 before and I had canflap on, I'm using a pc how can I turn canflap off? It doesn't respond to bc button on G20.
Default 08-01-2020, 04:53 PM
Not sure how you can turn it off via a PC. Mine works when I long press BC. I can even hear the flaps open and close.
Current:
Default 08-02-2020, 12:00 PM
I discovered mine works also but the vehicle can't be in motion, both arrows oem mode doesn't seem correct though, the flap doesn't open when I switch from comfort to sport plus.
