Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default water/meth injection in winter - 10-15-2021, 06:45 AM
Going into winter with my water/meth kit for the first time. I heard to add a bottle of Heet to the tank to prevent freezing since here in MN we can get to -40F and even washer fluid will freeze. Any thoughts or suggestions
JB4 W/FUEL WIRES & EWG WIRES
BMS INTAKES
BMS WMI KIT
BMS OCC
FUEL IT FLEX FUEL KIT
BORLA EXHAUST
STOPTECH FRONT AND REAR PADS
DENSO 5346
SEIBON CARBON FIBER OEM HOOD
NICHE 20" WHEELS MATTE BRONZE
DRONE MOBILE REMOTE START
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 10-15-2021, 06:49 AM
Meth freezes at -144 deg f. You're good, even if it's mixed with a bit of water.
Default 10-15-2021, 07:04 AM
The info I found on boostjuice which I run is -34f or so which we get that cold and even colder. Maybe a half a bottle of Heet?
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 10-15-2021, 07:55 AM
If you're using boost juice then maybe just a splash won't hurt. A plastic container is very pliable and forgiving, unlike a soda can. Worst case is it might get a bit slushy but as soon as you fire up the car the cab heat will take care of that, and engine heat will definitely thaw out any lines in just a minute or so.
Car: 2020 Genesis G70
Default 10-15-2021, 08:56 AM
Has anyone used Heet to increase Meth ratio? Reading other forums there are people using washer fluid and a bottle of Heet to increase the meth ratio to 60%. I use Boost juice but would like to increase the meth content from 49% to around 60% meth for track days
Default 10-15-2021, 09:39 AM
I would think like what I was saying maybe like a half bottle to the 1 gallon tank I would think it would net you around that 65-75% percent mark.
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 10-15-2021, 09:41 AM
Can't you find Meth local? I assume that you can't because of the question, but the most economical way is to buy 5 gal buckets. Much cheaper than boost juice and much cleaner.
If local isn't an option, then ensure you get the yellow bottle heet and not the red. Yellow is 99% Meth but the red is isopropyl
Default 10-15-2021, 11:06 AM
Freezing isn't usually a big issue on WMI kits, especially with at least 50% meth mixtures. I've never heard of anyone freezing even if "wind chill" temps get really cold outside as it's always a few degrees warmer in the car.
Lil Ripper's Avatar
Car: 2019 Veloster turbo
Default 10-21-2021, 12:20 AM
I mix my water / Meth to 50/50 and have never had an issue with freezing. I live in Canada in the praries where it regularly gets pretty damn cold. We had a few weeks last winter in the - 40s down to even - 50s for a week or so. If Its going to be super cold I would just add a little extra bit of meth to the mix.
