Hi,I am new to JB4. I send e mail to support already.
I update the JB4 to Firmware from 13/5//5 to 7,It will change the Map 5 to Map 4 when I FULL THROTTLE , it occurs after the first shift of the gearbox.
but there is no problem when I use the Firmware 5 , I try to wrote the 13/7//5 again but it's no working ,still got the problem.
My car is 320i n20 ewg,There is no problem before I update it ,I want to see the temperature to update the firmware,surely that is the new frimware cos it. would you pls help me get it back to firmware 5 or 6, because firmware is beta ,I'm worried that this will cause problems for my car
I will put the log for two firmware on map 5 . or should I do some setting??
pls help me to fix it
expecting reply ,thanks a lot !!!
